Quick question, Was just doing some testing and didn't understand why when you lets say input all stock factory data into the bluecat, generate the ve table then without changing anything in the ve, use the blue cat program to regenerate all zones, coefficients ...etc do you get different values from stock without changing anything. Should it spit out the same values? Or is it that I'm missing something?
