Has any had a coolant leak in the area I circled in the image?
It looks like maybe the seal for the coolant pipe under the turbo melted.
--Christian
--Christian
Happens when people get aggressive when mounting headers or am turbos. You bend or dent the pipe and it leaks
The banjo fitting on the coolant supply line had a cracked weld/solder where the pipe meets the round fitting.
I replaced it and all is well now.
--Christian
