Results 1 to 16 of 16
Thread: injector flow rate max help
    Jun 2012
    Denver, Colorado
    41
    I'm trying to maximize my injector flow rate for c6 corvette 2006 but its not allowing me the max value that I can add is 63.5. I'm installing a large injectors #80 any tips of how to rise the values ? thanks
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    If want to do it right it need to be scaled ....
    Or u can use double stoich and cut the IFR in half ... ( not sure if this will work in ur 80lbs injector )
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
    Jun 2012
    Denver, Colorado
    41
    Quote Originally Posted by 4evervette View Post
    Which value do i cut in half the 80 ? or the 63.5 ?
    or can i do the max the 63.5 and add the difference to the stoich ? Thanks
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Alfdhalah View Post
    You would put half of the injector value and double the desired stoich value.
    For example: 40 lbs/hr and 7.3:1 AFR
    Jaime
    No you want to go opposite:
    80 LB injectors = 40LB in IFR table
    STOICH AFR = Double so you want to take 14.68X2 so 29.36 afr
    Hope this helps, it works fine but your Fuel consumption on the DIC will be half too so looks like your car barely eats any gas when you set it to instant fuel economy lol.
    Quote Originally Posted by ElecTech View Post
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by mourat View Post
    You're right, my apologies.
    Jun 2012
    Denver, Colorado
    41
    Thank you so much guys i'll try it.
    A friend of mine told me that there is an easy way instead of x2 the stoich. you can max the FIR and then add the difference to the Map table like let say i'll go with 80 size injectors 65.3 is the max and then I add the 14.7% to the Map table do you guys think that will work ?
    Jan 2008
    dyno room
    169
    Which map table ?
    Jun 2012
    Denver, Colorado
    41
    I dont remamber exactly which one was MAP or MAF Table
    Jun 2008
    Ft Worth, TX
    22
    This is really the easiest way. It only takes a couple minutes.
    2020 C8 - just headers for now
    2007 Silverado 4.8
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    If you half the fuel density table your DIC will read correctly again.
    Oct 2013
    3
    Sorry for resurrecting an old thread... but when doubling the stoich AFR and halving the injector flow rate, is the only table that needs to be adjusted the injector flow rate versus pressure delta? Everything else can stay the same?
    Jun 2012
    Denver, Colorado
    41
    Hey CLM
    What I did is I followed Greg's Scaling DVD. I didn't cut half of the IFR and 2x the STOICH. but what I did is I scaled the whole tune MAF, VE, and Timing tables. it really takes time but in the end you will be pleased with the result.
    Oct 2013
    3
    Alright, thanks. I guess thats what I'll have to end up doing.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    The simple way works just fine.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2011
    Montreal, Canada
    758
    Agree. Been running with it done the "easy way" for 2 years and many upgrades and changes with no problems.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
