Results 1 to 20 of 21
Thread: VCM Scanner crash with standalone logs
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    I'm getting a weird crash every time I open a standalone log and try to display the status bits. I can look at everything else without issue, but if I try to open the status bit panel, or leave it open and load a log the program crashes. I've sent in a bug report when it crashed. This only happens with standalone logs, if I log with the computer there is no issue.
    28,774
    Post an infolog(so I can at least see what software version you are running) as well as the scanner log in question.
    Jul 2012
    371
    I think the info is what you need, let me know if you need something different.
    28,774
    Seems to open fine for me with the newest public build.
    Jul 2012
    371
    Huh....What do I need to get that version?
    Dec 2009
    1,084
    goto your customers page and download it.
    Jul 2012
    371
    Downloaded 2.24.144, everything works fine on my work computer, but not on my home computer.
    Jul 2012
    371
    Happened to me again, this time on the computer that the other file worked on.
    Dec 2009
    1,084
    Strange, I to got the error when viewing status bits.
    Attachment 40075
    I also sent the error report.
    My Suite Version is 2.24.71
    28,774
    Quote Originally Posted by planethax View Post
    Attachment 40075
    Make sure to update to the newest public build 2.24.144 or newer and try again and send a new error report if it crashes.
    Dec 2009
    1,084
    Updated to latest, still get error.
    I resent the info.
    Jul 2012
    371
    Dec 2009
    1,084
    I do not get the error on first log posted but do on the second.
    If Status Bit window open when opening log Scanner crashes right away.
    If Status Bit window closed I can view and run log.
    Clicking Status Bit opens window ok but as soon as you move the mouse it crashes.
    Jul 2012
    371
    I'm still having this problem. Any progress?
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
    Feb 2006
    Rancho Santa Margarita, CA
    906
    Same issue here with 2.24.246, i started having this issue probably around .204, don't recall having this issue with .77, but i see somebody had the exact same issue i have with .71, Object reference not set to instance of an object.
    This happens with standalone logs only, i installed .246 today, and now it's worst, before .246 i used to connect to the VCM at least one time, like to read a log having the laptop connected to the VCM, and sometimes this was allowing me to open the standalone file, now, no matter what i do, i can't open any standalone log.
    Posting one of the logs in question along with the info log, it's frustrating to know something is messed up like this, sometimes it'll open, most of the time it will not. logs taken from the laptop work withot issues, but i can't have the laptop with me 100% of the time.
    Please help, and yes, i've been hitting the send error report like crazy, you guys should have a lot of data to fix this by now
    Regards,
    Feb 2006
    906
    Lol, with my luck, i was able to open up the file, all i did was to run the vcminflog, and it's working again. Tomorrow i'm sure the issue will come back, please HPT fix this issue, it's so frustrating......
    West Texas
    13
    "Object reference not set to instance of an object"
    still getting this error when starting a VCM scan. Sent an error report. Any news n how to fix?
    Dec 2009
    1,084
    For now, open scanner (not log just scanner)
    Close Status Bit window, then open log.
    You can play log but do NOT open status bit window or you will crash.
    28,774
    Because we are rebuilding the scanner from the ground up in 2.25 we won't be fixing any additional scanner related bugs in 2.24 as it would just hold up 2.25 developement.
    West Texas
    13
    Thanks for response, but I need to clarify. My error occured on first read of VCM, I actually put scan in previous post, but I was actually doing an initial read. Will closing the status bit window correct so I can pull my initial scan?
