P0452 DTC not clearing
Hello,
I flashed the PCM three times now and for some reason, I still get a DTC for
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage, even though I unchecked it from the DTC list. the scanner picks it right up, right away, even when I reset the DTC list in the PCM.
Is there something else that I need to do in conjunction with turning that DTC off?
My application is a V8 RX-7, so I am not sensing the fuel tank pressure. Your help is greatly appreciated! Zach
Nevermind. I forgot to set the error mode to 3.
