Originally Posted by
carlrx7
Question, How are you tuning it? You don't have a 2bar MAP so you can't be running SD, but I dont see you logging MAF HZ. In the tune, you have the MAF set to fail, but the DTC codes dont look to be set right. VE tables dont look realistic. PE + BE set to 1.35 = 10.88AFR . just a couple things I noticed. The big one is you trying to run in SD with a 1BAR MAP sensor,
A quick rundown...
1Bar = 0psi
2Bar = 14psi
Send a message to DSteck and get yourself a 2.5 bar map sensor, his are plug and play.
-Carl
