Page 34 of 44 FirstFirst ... 24303132333435363738 ... LastLast
Results 661 to 680 of 861
Thread: Ford tuning in AUS
  1. #661
    Feb 2010
    Perth Australia
    480
    Quote Originally Posted by Hiboost-xr6 View Post
    Attachment 42314
    Hi all,
    finally got to read my tune here it is for you guys to have a look at haven't had chance to data log yet.
    File is in this post J@ Throttle tables are normal but it is running a bucket load or cam retard from .2 lo to .8 from 1200 to 3500. Peak is 13 deg higher thans stock.
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
  2. #662
    Quote Originally Posted by 45T-XR View Post
    It sounds like the old LED tail light issue Ive seen it a few times now, Even Orangeute had the same drama but i believe his load resistor had failed.
    But if you dont have LED tail lights this wont be your problem lol. What Jet said, what codes are you getting, you will need to log with SCT to see what sort of limiting is coming into play when the fault occurs. HP doesnt have access to it from memory
    maybe something else is causing it to go into reverse mode?
    you can tell because standard reverse is limited to 3500rpm and about 30% throttle, so you can tell if it has limited throttle then switches to full throttle at about 3500rpm then thats the problem.
  3. #663
    does anyone know what the values in the cam tables refer to
    say a stock bf f6 file at last load line runs -9 till 3500 then 10.
    i know the sprockets have about 16deg of movement eitherway. but the table the numbers dont match up
    does changing the table with a bf with the dual vct work? i know you can adjust them seperate in hp but does adjusting it stuff the stock setup or does it just offset them from where they are from factory? or does it just make them like a ba and move the same together?
  4. #664
    Nov 2013
    kurrajong heights nsw
    14
    does anyone have a stock BA turbo auto file so I can compare some numbers?
    so should I be looking at the vct settings?
    Neil
  5. #665
    May 2011
    New Zealand
    34
    Completely stock BA XR6 turbo
  6. #666
    Nov 2013
    14
    Quote Originally Posted by ptharris View Post
    thanks ptharris
  7. #667
    Aug 2012
    238
    I put some 1500cc injectors in my FG. I find that the air/fuel ratios change when the outside temperature changes. I trim the fuel at idle and cruise to trim at around the 0% mark. When the weather warms up it trims to around -8 to -10%.
    Is it normal to have to play with temp compensation tables when using such big injectors. What compensation tables are there in HP for our Fords. Under Airflow/general/speed density there are three correction tables. Which is the best to use to help with this issue?
  8. #668
    Aug 2012
    Melbourne Australia
    344
    Quote Originally Posted by turbotrana View Post
    turbotrana, anyone?
    Do you think you are getting something like what is described at the end of Injector Dynamics Paul Yaw's GT500 article (great read as it also goes into Fords speed density):
    http://wpdev.injectordynamics.com/ar.../shelby-gt500/
    Have no idea if these tables exist in HP tuners and would suspect the PCM would have to calculate rail temp like the table "Hot Enrich" under Engine -> Fuel tab.
    Darryl.
  9. #669
    Oct 2007
    Crawfordville, FL
    2,468
    Is the car leaner when cold or richer?
  10. #670
    Aug 2012
    238
    Sorry about the late reply. I did want to do some more testing before I responded but haven't had a chance yet.
    It runs leaner when warm Eric.
    Darryl, yes that is definately applicable. I don't think we have fuel temp comp for the Aussie Fords. According to that table, as the fuel gets hotter, more fuel is needed.
    I did play with what compensation tables were there and there were improvements. When I have time I got to get back onto this and nut it out.
  11. #671
    Oct 2007
    Crawfordville, FL
    2,468
    I will see about adding the remaining tables that would affect this. Pretty sure the Australian Fords have the Lost Fuel tables. I need to add them to every definition. I will put this on the list. If you tell me your specific OS ID, I can put it in there first so you can test.
  12. #672
    Jul 2009
    326
    They do have the lost fuel tables (enrichment lost load) but don't forget about the fact we're using a speed density algorithm for airflow which is more sensitive to temp corrections compared to you x transfer / maf set-up. You could also look at the Density Correction for Aircharge? There is also three tables for injector enrichment when hot and the values differ between strategies. Obviously when rail temps rise the fuel flow drops so you would think these tables increase the pulsewidth under these conditions. Given that there is not rail temp sensor, it works off a 'time since running function'. How active these are will depend on the strategy i suspect. Its sometimes difficult to test these in an 'uncontrolled environment' given you can't make real time changes to the calibration.
  13. #673
    Aug 2012
    238
    Thanks Eric,
    HAEDJR5
    8R29-7J104-AB
    Thanks Toads
  14. #674
    Potential Tuner Monaro 383's Avatar
    Jan 2012
    Melbourne, Victoria, Australia
    9
    I know it's already been said but massive thank you to IH8TOADS for all the info in this thread it's a massive help if your new to the Ford Turbo tuning world.
    I just put a set of Bosch TCP1000 injectors in a 2010 FG XR6 Turbo today and just wanted to share my thoughts that they are the best injector I have used so far, don't let the size scare you there idle quality is better than 60lb Deka's which in my opinion aren't real tuner friendly anyway but everyone has there own preferences, from my point of view I think they are worth the extra money.
    Cheers
  15. #675
    Tuner in Training F6R's Avatar
    Nov 2009
    Perth, Western Australia
    42
    Good to hear the positives on those injectors. I was contemplating an upgrade from the 968's I have now and will probably go that way.
    Care to share the set-up values you used?
  16. #676
    Oct 2011
    QLD, Australia
    436
    I think we need to vote#1 IH8TOADS for Australian HP guy. LEarnt more from TOADS via message than I did at the HP course in Melbourne lol
  17. #677
    Oct 2007
    Crawfordville, FL
    2,468
    Quote Originally Posted by IH8TOADS View Post
    I'll try to find the time this week to get this in for you guys.
  18. #678
    Jan 2008
    Sydney Australia
    55
    Can anyone explain why knock cannot be logged in the turbo falcons like most other vehicles. Is the information not in the ALDL data sream or is it in a format that VCM suite cannot read.
    I know it is being done with things like "knock ears" however nothing can beat logging and lining up with all other necessary parameters.
    On another note can anyone tell me how to get a 0-5 volt square wave signal for rpm from a turbo falcon this can then give a stand alone logging system which can monitor knock.
  19. #679
    Oct 2011
    QLD, Australia
    436
    HP Tuners dont have the DMR's specified for Knock Retard, but Eric informs us that a big scanner update isn't too far away, you will probably find the MAP doesnt work either, you get some real funky values. You can't get a square wave tacho signal from a falcon from memory for shift lights, eboost etc, you need a tach adapter. I bought a Autometer one a while ago to use with the eboost but i havent fitted it yet.
  20. #680
    Jan 2008
    Sydney Australia
    55
    Without a knock pid it is impossible to accurately map the knock threashold even a knock sensor voltage would be better than nothing. My map reading appears to work fine (FG).
    Tried an Autometer tach adaptor it would not supply a signal good enough to feed another PCM (holden) for logging knock on the falcon.
    I was under the belief that logging knock would be extremely unlikely with the turbo six falcons, even bought an SCT to log knock that would not do it either which may indicate it can not be done hence the original question.
