Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: 2 bar map sensor for BA Falcon 3V
    is the v8 map sensor the same as the na 6 map sensor? if thats the case the turbo one needs a different plug and you just wire it back to front. so say the na map sensor is 1234 wires you just go 4321. guy who sells the knock box sells the plug and play looms which are about $30 otherwise the correct plug for the ba turbo map sensor is about $30 also.
    ba turbo reads upto about 26psi also
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    Pegs at ~22psi
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Dec 2005
    Sydney Australia
    510
    yep 2.5bar there abouts..
    Aug 2012
    7
    Quote Originally Posted by VYSSLS1 View Post
    use a xr6 turbo map sensor and enable turbo logic and the job is done..
    For those playing along at home, he is completely correct.
    One question for VYSSLS1, when I enable turbo logic, the map sensor is working, the car starts fine, but the reading is 12kpa flat in my logs. Do I need to enable "boost sensor" also?
    Dec 2005
    Sydney Australia
    510
    no you have the sensor wired incorrect..
    the wiring needs to be reversed in the plug.. BUT it still goes pin 1-1 2-2 3-3 4-4 etc.. the number 1 pin is just at opposite ends of the sensors..
  6. #26
    Aug 2009
    Naples, FL
    339
    OP, What pcm is in use on your car? wondering if its even remotely similar the PCM's used on the 3v mod motors in the US.
  7. #27
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by Fire67 View Post
    Most of them have 1024K Spanish Oak
  8. #28
    Aug 2009
    Naples, FL
    339
    Eric, so they can effectively run multi-bar OS? Pardon me for reading between the lines, but it would be awesome if we could run a true speed density setup on these Fords.
  9. #29
    Oct 2007
    Crawfordville, FL
    2,447
    There is no VE table. It's much like the speed density calculation that the US vehicles have.
  10. #30
    Aug 2009
    Naples, FL
    339
    Oh ok. Understood.
