Results 1 to 10 of 10
Thread: 2011 CTS-V, REP only at WOT, P1516 code?
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Hey guys. It's been a long time since I have been on the forum, but just recently I put together a customers 2011 Cadillac CTS-V Coupe with the modifications as follows.
    LS9 cam
    D3 Cadillac Heat Exchanger
    Stainless Works Headers with 2" primaries and 3" collectors
    High Flow cats
    Lingenfelter 2.55" upper pulley
    D3 9.0" lower pulley
    Nitrous Outlet spray bar/lid spacer system
    D3 Cadillac 4" Cold Air Intake
    ID850 Injectors
    Standalone C16 fuel system in the trunk.
    Tonight was the first night I took it out of the shop for some street tuning. It's real rough, but I was trying to dial in WOT fueling with no nitrous. However, every time I'd stand on it it'd go into REP with a reported P1516 code and some other one about MAF out of self test range.
    I disabled all the Airflow checks in the diag section, and maxxed out the airflow values to no avail. When the car rolled in it did not have this issue. But now that it makes about 14 psi every WOT hit REP pops up. Am I missing something here? Log and tune attached.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Nov 2009
    All Around
    3,149
    Did you check if the blade of the TB is hitting anything, possibly the piping to the TB? also under torque management look at your boost MAP enable usually I just increase it over stock
    Aug 2010
    Roswell, N.M.
    1,956
    No I have not checked the piping, although that's a damn good theory. I will run out the shop and see if I can find anything.
    As for the boost diag, I think I bumped it up quite a ways but will double check.
    Thanks for chiming in.
    Aug 2010
    Roswell, N.M.
    1,956
    Update. I checked the plumbing to TB, and it is miles away. I'm going to try a pedal relearn and a TB clean reset to see what it does. If it doesn't fix it I'll throw a truck Throttle body on it. And I guess move onto the pedal if all else fails.
    Dec 2006
    Pensacola, FL
    496
    Did you apply the MAF Patch? I'm at work and can't download your tune to check.
    Aug 2010
    Roswell, N.M.
    1,956
    I'm sorry? MAF Patch? The E67 doesn't display that as an enhancement.
    Dec 2006
    Pensacola, FL
    496
    Quote Originally Posted by IDRIVEAG8GT View Post
    My bad, I was thinking you had a E38/E40 computer.
    Aug 2010
    Roswell, N.M.
    1,956
    Not really sure if it's the culprit but I wiggled the connector on the TB with it running and it went into REP, however it threw several different codes having to do with High Voltage. I'm going to trace the wires and see if I can find a short or something and test it again.
    Dec 2006
    Pensacola, FL
    496
    I think you might have found your problem...LOL! Good luck.
    Aug 2010
    Roswell, N.M.
    1,956
    Yep sure did! I have absolutely no idea how but the inside of the TB plug was full of antifreeze. Strange it even worked at all! Thanks guys for your help. Now on to change spark plugs!
