I was wrong on the reduced power mode so ignore all that crap above from me, I had changed something else with it and that was the reason for the change. So last night I went through and made some changes off a cruise file I saw and boom that was it 3 tables fixed my issues. Now Holding 84% from time I nail it to time I let off boost staying at my max setting and not any knock at all. Logging is weird I am seeing a spike of over 500 ftlbs tq then settles in around 420 and tapers off to 6600 shift point at like 340 then of shift back up to 410 -420 repeat. But when first punch it get that huge spike over 500 which is weird. Car pulls very hard mid to top end but some how have gave up low end and spool time. seems the car is slower to build boost . So any ideas what could cause it? I didnt touch the prop gain which I have read can change that but still stock settings as no idea where to go on it. So something else I did is doing it so asking which table could be the culprit as I have raised most and none are lower than stock at any point.
