Page 14 of 20 FirstFirst ... 4101112131415161718 ... LastLast
Results 261 to 280 of 399
Thread: Incorrect / Missing Parameters? Let us know
  1. #261
    I just came from newer Mustang, 2008, same, no mixture change, OL or CL, there is fixed wideband installed. I tested only idle this time.
    edit, additional test.
    20 percent rich at idle, 0 part throttle and 10 lean wot, no matter what LWFM set, even zeroed, maxed. Car drives normal.
    As on another tested before...
    So again, if someone will have 3v in his hands, please do same thing for test and let here know how it looks.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
  2. #262
    Oct 2007
    Crawfordville, FL
    2,447
    Both load w failed MAF tables?
    Eric Brooks
    HP Tuners, LLC
  3. #263
    For test i'm changing always both.
  4. #264
    Another mustang, completly stock except jlt cai. I've put original Ford racing tune for test and only cange was I've put maf transfer for jlt 110.
    See compare, nothing has changed after both LWFM were set to max so 1.99.
    01. stock ford racing tune but jlt 110 maf.hpl
    02. stock ford racing tune but jlt 110 maf_LWFM 1.99.hpl
    www.hd-customs.pl
  5. #265
  6. #266
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by caniggia View Post
    I see a 25% difference between the two logs, so there is a change taking place. The O2 voltages reflect changes as well. I haven't looked over everything that you have posted, but I still feel like the issue lies more in how the scanner is showing you the data than an actual template issue.
    I would suggest starting another thread to keep this one from getting bogged down with logs and things. You have gotten it on record and Eric is aware of it. Honestly, it doesn't sound like its going to get resolved real soon.
    Just my opinion. If I could test it for you I would, but I would try reducing the number of logged items to just the basic items needed to log load, TPS, and Fuel Trims to see if a clearer picture appears.
    Jaime
  7. #267
    In real theres no difference between those 2, difference is only time of log, so this may cause what you see. With 1.99 lwfm he should be rich like hell.
    I think i documented this enough, so maybe Eric will find out.
  8. #268
    Apr 2007
    30
    2012 Mustang, purchased 2 credits, running beta when ever I change the revs per mile to 770 and save it, then reopen the file, its changes to some crazy number this is with vid disabled.
  9. #269
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by 1998purplez28 View Post
    Fixed today.
  10. #270
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by Blazin72 View Post
    How about a disable skip shift feature for the 2011-2012 cars? I just looked through mine and I didn't see that option anywhere.
    Added today to all Manual transmission definitions, including the manual transmission gear ratios.
    Eric Brooks
    HP Tuners, LLC
  11. #271
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by Ortiz View Post
    Can we get Commanded Lambda When Fuel is Overridden?
    It has been added to all OSIDs.
    Eric Brooks
    HP Tuners, LLC
  12. #272
    Jun 2005
    Southern FL
    2,044
    Have you found how to modify mixture in sd mode?
    How are you setting the MAF failed to obtain SD mode? And, curious, why are you tuning it like this? Why not input the Loads you see when the MAF is enabled into each cell of the LWFM table? You can easily set the TP to only open so far, go out and make a run in say 3rd or 4th gear, then input all the loads you're logging for each TP position vs RPM. If your MAF is dialed in correctly, that'll get you pretty damn close.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
  13. #273
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by RWTD View Post
    I agree.
    I did go through the logic and all that is used is the LWFM table, and there are two adders which are zero'd out for this application. One was an adder for EGR and I don't recall the other.
    Eric Brooks
    HP Tuners, LLC
  14. #274
    Mar 2008
    Paris, France
    435
    F250 transmission Tuning are very poor, is it on the road map to add parameters ?
    http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
    Check our Facebook page http://www.facebook.com/lsxcalibration.com
  15. #275
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by Brice View Post
    Yes, is there a specific example you have for what is missing that you would like to see? I like to keep a list.
    Eric Brooks
    HP Tuners, LLC
  16. #276
    Mar 2008
    Paris, France
    435
    Quote Originally Posted by Eric@HPTuners View Post
    Well ... the same than the F150.
    Here is the only parameters I've got :
  17. #277
    28,312
    post the .hpt file.
  18. #278
    Mar 2008
    Paris, France
    435
    F250 stock
  19. #279
    Sep 2011
    Germany
    197
    On Ford F 150 Raptor BBHH4K2 Tire Revs per Distance is Missing to adjust speedo.
  20. #280
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by zr1driver View Post
    I am aware of this, as that parameter does not exist on the trucks. It is replaced with another one, and I have to code it. I may get it done today.
    Eric Brooks
    HP Tuners, LLC
