Results 1 to 11 of 11
Thread: Does HP tuners have the ability to run the automated ABS bleed procedure?
    Need to do this on an 01 Trans Am and I'm not sure if I'm just missing it in HPTuners, or if it just doesn't have the ability. Thanks.
    2001 Pontiac Firebird Trans Am
    1995 Jeep Cherokee
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    It's not in the software right now.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Bummer, ah well. Fortunately it does everything else I need I'll just run it to the dealership to get them to do it. Thanks.
    1995 Jeep Cherokee
    Mar 2008
    St. Louis, MO
    4,863
    It'd be nice if we could... I would love to be able to properly bleed my brakes myself!
    Tuner smokestack's Avatar
    Jul 2011
    West terre haute Indiana
    111
    What is it im missing here? Or is it some ABS bleeding or something? Purge the ABS pumps or something?
    Mar 2008
    St. Louis, MO
    4,863
    Quote Originally Posted by smokestack View Post
    The Tech-II can do a procedure to cycle the ABS solenoids to purge air out of them when you're bleeding the brakes.
    Mar 2009
    Earth
    213
    It sure as hell would be nice if this was implemented into the software. It would make a big dent in ever needing a Tech II.
    May 2014
    33
    Question
    Has this functionality been added? I too need to command the ABS solenoid open to purge air out too on 4th Gen F-Body cars!
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,023
    you don't need to do abs bleed. I have tech II never use it. this is what I do, drive down road, slip one side of car off road surface and lock brakes it will cycle one side of pump, then do other side, do this 2 or 3 times, and much much quicker than trying to do through tech II. you can do all for corners at once with speed and locking wheels up at once just a little harder to do. And by the way, when I was with GM had an engineer that built the abs bleed into the system, that told me to do that. so that should tell you something there
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Sep 2008
    1,668
    I've tried using the Tech II method...it's annoying. Just flush the fluid in the car, then go out in a giant empty area and stab the brake pedal as hard as you can so the ABS actuates. Do that 2 or 3 times and then go back and bleed each corner the old fashioned way. Doing that gets me a firmer brake pedal...tells me it's working better.
    2023 Durango Hellcat
    Sep 2002
    Chicago, IL
    6,397
    Mike, that's the same method we do in our 96 V6 Firebird lemons car. Works just fine.
    We got this guy Not Sure, ...
