Results 1 to 20 of 25
Thread: NGK AFX accuracy
    Sep 2011
    Portland, OR
    523
    NGK AFX accuracy
    Some of you had your AFX modified.
    I'm curious how they work after the modification? And how does the accuracy compare to before?
    I'm also wondering if any of you have used the test gas dyno guys use to test accuracy?
    I believe there is a 13:1 and a lower value as well.
    A good friend tested his LC1, and AFX with the 13.1:1 gas and found quite a discrepancy. Up to .7 AFR too rich.
    Ron
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    Mar 2014
    Easton, PA
    16
    What do you mean modified? As in the input PID? I verified the voltage from 0-5 in hptuners to ensure it was accurate. I'm also using the ngk sensor and not the bosch. You should verify both against a professional wideband. That would probably give you your answer.
    Sep 2011
    Portland, OR
    523
    Guys were sending their units back the the manufacturer for updates.
    Quote Originally Posted by RonSSnova View Post
    I think most were sending in their AFX's to display lamda on the screens vs. showing AFR.
    Sep 2011
    Portland, OR
    523
    Correct. They also extended the range.
    May 2010
    250
    The new NGK unit is out now.
    Sep 2002
    Chicago, IL
    6,397
    I run two older style NGK AFX's in my race car. One in each bank.
    They are .5 AFR different and its something I've been working on figuring out why.
    Perhaps I'll try the new units to see if they're more accurate.
    We got this guy Not Sure, ...
    May 2010
    250
    My ngk unit died and they discontinued the gen 1 and support for it so I have been waiting on the new one. I run one of them in one bank and the FAST dual unit in the other and compare them.... the NGK was better but I have the FAST still so have been running it
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    Quote Originally Posted by Keith@HPTuners View Post
    Swap sensors left to right. Then swap boxes. Then swap harnesses. See where the switch occurs. I have five AFXs (well, AFM-1600s) in my rotation, and each one reads within 1% on the same vehicle. You may need to free air calibrate them too. Are you using the NTK sensors?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Sep 2002
    Chicago, IL
    6,397
    Yea, i haven't had time but I understand the process. It's just time consuming. First order of business though is to have the injectors flow benched.
    I'm pretty sure I'm using the NTK sensors.
    I think I may just order the new NGK units though and start from there and use the ones I have in our lemon car.
    Oh, so on my race car I melted the harness plug where the O2 sensor plugins into the master harness. We can't separate the plugs anymore. I called up NGK asking if I could just buy those plastic connectors so I could re-pin the harnesses. Nope. I have to buy a new harness + O2 sensor. Might as well buy a new unit. Oh well.
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    I'll buy your old one with the melted harness if you wish to sell it with the damage considered in the price. Let me know.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Mar 2008
    St. Louis, MO
    4,862
    $20 and a hammer will get you back going. Ballenger Motorsports sells the connectors, and you can just smash the melted plug to get it apart. I've done it once or twice (or four times).
    The new NGK wideband is not made by ECM. I wouldn't expect as good of accuracy (although it's unproven).
    Jun 2006
    San Diego
    134
    Is that right? Who makes the new version then?
    Got GEN II-IV LSx or GEN V LTx parts to sell? Post em completely free on LSx LTx buy/sell/trade Facebook group. Invite your friends.
    https://www.facebook.com/groups/169854669867850/
    DO YOU OWN A FORD, DODGE OR GM ALLOYTECH VEHICLE AND GET A MESSAGE SAYING "VALIDATE CHECKSUM FAILED. YOU WILL BE UNABLE TO SAVE OR FLASH THIS FILE." IF SO FOLLOW THE LINK BELOW.
    http://www.hptuners.com/forum/showth...lash-this-file
    Dec 2008
    on the Dyno
    1,825
    Yes it is right. I asked ECM when I was on the phone with them a few weeks ago and they said no. I'll keep rocking my old AFX/AFM1600 units.
    Also that test gas method is rediculous. Most all of Innovates products kill sensors prematurely and do not stay reading accurately vs various exhaust temps. I often tune cars that have the widebands already installed in the car and they question why I still put mine in the exhaust then I show the descrepancy while tuning on the dyno. My V1 NGK's have never let me down.
    Keith hit up Ballenger Motorsports for the plastic connectors. I've melted half a dozen myself and keep those little connectors in my tool box just for that reason.
    Located in Central Kentucky
    ShorTuning
    Can you actually call ECM and order an AFM-1600? I don't see it on their website?
    Sep 2002
    Chicago, IL
    6,397
    I just picked up two NGK AFRM's that I'll be putting into the car. We'll see which one of my AFX's was off, or if my car is a piece of crap.
    It appears that I'll also have to add the AFRM to the list of predefined wide bands in VCM Scanner.
    Mar 2008
    St. Louis, MO
    4,862
    Keith, do your AFX widebands use NTK or Bosch sensors? Wanna sell them?
    Sep 2002
    Chicago, IL
    6,397
    I'm pretty sure they use the NTK's.
    First I'd like to find out what the discrepency is between the banks. Then I might take one and run it in our lemons car and keep the other as a spare.
    Sep 2002
    Chicago, IL
    6,397
    FYI, I've added the AFRM as a built in AUX input to 2.24
    Sep 2002
    Chicago, IL
    6,397
    Swapped the units between banks. It appears that one of my banks is just running richer than the other. Could be a small leak in the 5->1 merge.
