Right now I'm trying to decide between EFILive and HP Tuners.
Specifically, to do this conversion below on my 2012 Chevy Volt/s.
https://forum.efilive.com/showthread...uel-Conversion
Apparently, the Volt uses the same GM Part number for the ECM as the Cruze ECO.
A major deciding factor for me to go HP Tuners is if these same Flex Fuel Parameters are available to be edited in VCM Suite, as they appear to be with the Cruze ECO using EFI Live?
{B0178} Flex Fuel Option
{B0184} Flex Fuel Sensor Type
{B0189} Detect Ethanol Change
{B0187} Ethanol Change Delay
{B0188} Ethanol Change Amount
{B0186} Flex Fuel Sensor Diagnostic
Has anyone seen these parameters as being available to be edited using HP Tuners on a Volt or the Cruze ECO?
