Results 1 to 5 of 5
Thread: 2007 Dodge Dakota 4.7 - About to start tuning
    Oct 2007
    Lawrenceville, Ga
    332
    I have done much to my 1998 GTP in the way of tuning, but have never tuned anything else. I just bought a 2007 Dodge Dakota and wanted to start tweaking, but I'm not sure there is anything to gain on a stock setup. I've looked on here and on other sites, but have not read anything about tuning these motors. I don't see any problems while scanning (knock retard is always 0 and fuel trims are damn near perfect). It seems a little weak and gas mileage is low, so I was going to start by playing with timing first.
    Has anyone done anything to a 4.7 in the way of tuning? If not, I'll post what I do but like I said, this is completely stock.
    -Eddie
    1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - Gen V - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
    1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60' (before Gen V or ported heads)
    2021 Chevrolet Colorado 2.8 Baby Duramax
    I have no help to offer, but post up your datalogs as you go. I have a co-worker with a 4.7 Dakota that has been inquiring about having me play around with his truck. I'd like to learn about what this motor likes along with you.
    Advanced Tuner Screamn03's Avatar
    Feb 2004
    Vacaville, CA
    832
    I have a 2006 Dakota with the 3.7 that I've started to mess with, the biggest improvement so far came from adjusting the power enrichment settings. My truck would make it all the way through 1st gear before it started to enrich and wouldn't be fully in power enrichment until after the 1-2 shift. Not sure how the 4.7 is setup but I would start by looking there.
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    11.301 @ 129 1.68 60' MT DRs
    11.85 @ 124 1.90 60' street tires
    I have done lots of 4.7s but not with HP. Get rid of the delays to PE, and do not go crazy on WOT timing.
    Aug 2020
    Quote Originally Posted by FlyinRyan View Post
    hi i was just wondering if you could drop a tune file down just so i can see how it looks thanks
