I noticed this about a month ago and wrote it off to being plugged into a different car. Now I have plugged it back into mine and it does the same thing.
What happens is that when I record with the MVPI interface I get a MAP sensor reading that is extremely low, but when it is recording through the laptop it is just fine. Anyone ever had this problem? I'm very confused...
I attached two different quick logs within seconds of each other. First using the laptop then unplugging the interface and recording with that. It worked in the past and nothing has changed to my knowledge. I even made sure to rewrite the config file to the interface just to make sure that wasn't the issue.
