want reads from ford fiestas ford K let me know
No EEC-V definitions have been done at this point. Right now, only reading is enabled as we make sure the reading process works over the wide range of EEC-V PCMs (there are several different flavors). This also lets us see what kinda vehicles you guys are likely to be tuning, so we can prioritize which definitions are done first.
Eric Brooks
HP Tuners, LLC
I am reading a 2004 Mustang right now and will be sending it in to support soon. Any eta on when we will be able to tune?
How is this coming Eric? Is there any reads needed in particular to help you moving forward?
I tried to read my 2003 Cobra, but it takes too long. While reading it turns the cooling fan on 100%, and it says the read will take almost an hour. That equals a dead battery. I will try again and unplug the fan.
Also, how is support for these coming? I held off buying the SCT stuff to tune my car for this. If there is any way I can help let me know. I just might have an excel spreadsheet or 20 I can send you.
Hey dude are you sure that the fiestas and kas use ECC pcm's? im in mexico so i have acces to a lot of those little cars and they are fast with turbos but we have to use AEM piggy backs to run them so let me know if we can make some noise to suport so thay can take us in consideration
Ill send them in a Pm tomorrow eric thanks a lot
This is great news, I've turned away customers requesting their 03-04 cobras needing tuned. Thank you so much for incorporating the EEC-V into the supported vehicles list soon. Now i don't have to screw around looking for other tuning solutions when i buy my 04 cobraHP Tuners FTMFW
The Daily: 08 SS/TC, fully built 2.0L LDK, Wiseco pistons, K1 rods, ARP head studs, upgraded main bolts, S257sx-e, Opels, ZZP stage 2 cams, BRC 5th injector, E47, AEM E85 fuel pump, custom 3.5" intake and PCV system, custom catless downpipe, 4.05 LSD, custom KY frankenclutch, ZZP full 3" catback with res and muffler, lowered on CM springs, lots of other ZZP parts, built and tuned by BRC Tuning.
PICK TWO: CHEAP, FAST, RELIABLE
Stock 2003 Cobra file sent to support.
-Michael Rudolph-
2003 Redfire Cobra
Eaton Poweredto a:
11.301 @ 129 1.68 60' MT DRs
11.85 @ 124 1.90 60' street tires
In Germany 2005 Fiestas with rocam Engine use Siemens SIM21 ECU´s
no the european are different. the siemens ecu only have one connector. EEC-V was the last EEC module in Germany.
Any news on the EECs controlers i know the tech guys are all over the new 2.25 scanner and new definitions but hows going for the old pcms?
all the way from Tampico bay Mexico
Still working on it.
Eric Brooks
HP Tuners, LLC
I sent in a read and data log for an 02 Harley Davidson. I want to be sure you got it so you can add them to your list. I was told they aren't supported yet which I know but do you plan to support them along with the lightnings when the time comes? Also, any idea when they will be?
2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
