Results 1 to 5 of 5
Thread: Ltft and stft at 0 but engine running super lean
    Oct 2014
    Houston TX
    39
    My commanded afr is 11.5 . My engine turbo. Whatever table I try to change i cannt get it to riches up.
    Can someone send me in the right direction?
    98 PCM. Intense tune. L67 with st2 cam, Northstar TB, 03 Northstar Maf
    13,615
    Post the tune.
    Ever try adding 5% to the MAF table to add fuel, thats the best way to do it.
    Oct 2014
    Houston TX
    39
    Sorry im a noob and thanks for the responds. You have a pic of the table you are refering too? The northstar Maf I have on it should tune the same as a stock maf?To post the tune ,you just export on a certain screen?
    Thanks again
    There is something odd I noticed when I set up the histogram for maf tuning. When it's at 0
    the engine runs very rough and lean afr 18(rev it and it doesn't die and afr gos down)
    When I get the afr to an acceptable say 12 or so the histogram is saying -100.(idles good but when u rev it ,its unstable leans out and dies)
    Nov 2002
    Central Florida
    2,503
    I think you should take a little step back, and determine
    whether all of your instruments are trustworthy. In the
    case of the wideband, that would include misfire and blow-
    through (overlap) errors caused by exhaust air, as well as
    any scaling issues with the software at both ends.
    LTFT and STFT at zero means either deliberate open loop,
    from the tuner, or fault induced open loop (things like O2
    sensor codes, ECT out of range, etc.).
    I don't know what histogram you are talking about but
    I'm no fan of histogram based tuning for fuel; knock retard
    and timing table tweaking is all I can trust that for (and
    this, because I'm content with a little bit of conservatism
    in the timing). Fueling, experience says there's too much
    garbage in the data to trust its statistical rollup.
    If I were you, I think I'd be trying old-school idle mixture
    and low-RPM-mixture tuning methods. Tune to minimum MAP
    for a given RPM and load, and you're certain to be giving
    the motor what it wants (subject somewhat to timing; you
    will take a few passes around that loop I expect).
    Get it running shade tree style and see what your wideband
    says.
    Oct 2014
    Houston TX
    39
    Thanks I'm going to get back to it in a couple days when it warms up
