Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 130
Thread: 6l80e with tap shift no BCM
    Dec 2012
    48
    Ive been doing a bit of research on 6l80e - e38 6.0lt conversion with tap shift, from what ive found you wire as per corvette 2011, and adjust the settings an the ecm but from what i can find it seems only EFI live offer options for tap up tap down input type as per picture.
    Is it just me, maybe i simply cant find the option, how have others got this to work.
    Dec 2012
    48
    looks like i found the option!!
    Are you using the t43 tcm? Can you elaborate on how you got it to work?
    Dec 2006
    Pensacola, FL
    493
    Quote Originally Posted by xrelapse13 View Post
    Under the general section you have to change the TUTD setting to "hardwired".
    Oct 2014
    3
    Quote Originally Posted by HartRod View Post
    Do you know what pins are used?
    Dec 2006
    Pensacola, FL
    493
    My harness is modeled after a 2011+ Corvette.
    Dec 2006
    Pensacola, FL
    493
    Quote Originally Posted by s10mods View Post
    Here's a schematic.
    Dec 2014
    Australia
    Hi Guys, Ive got a Nissan Patrol here with LS3 and 6L80, using the Nissan TUTD shifter.
    It doesnt have the extra position after D like a Corvette has to pull it into Sports mode.
    It will only move sideways into the TUTD position.
    Did you get your TUTD to work ok. I have it enabled and hardwired in the Corvette calibration
    Is there a trick to this
    Any help appreciated
    Dec 2014
    5
    Quote Originally Posted by Hooter View Post
    I have similar problem. Have you got the tap shifting working?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    First off, you need to make sure he the resistor ladder for the switches matches what the TCM wants. You also need a way to tell the TCM what shifter position you're in. I'm not sure what you've got will relay that.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jan 2009
    Spokane, WA
    480
    I'm having a problem getting this to work with truck PCM/TCM (07 Yukon and 08 Escalade) - same problem, two different rigs.
    I have the pin in the TCM connector like it shows, the resistors like they show, and the TCM settings like shown. Tried every gear and still shows 'manual control off' and won't work.
    Any ideas? What am I missing??
    Dec 2014
    5
    Where do you see 'Manual control off'? In hp tuners? I have similar setup. Hard wired resistors to the tcm an changed the hp tuners settings like you did but no success.
    Jan 2009
    Spokane, WA
    480
    Quote Originally Posted by jonasj View Post
    That was my customer, he is using a SnapOn scanner. I'm at the shop looking right now, and I think Tech2 calls it..
    Driver shift control - active
    driver shift request - none
    I have not programmed this TCM yet, but I believe it was last set to a truck, meaning it's looking for BCM tap shift. I just flashed it to a 08 Corvette with the Tech2, so now i'll try it again and see if the driver shift request changes.
    Feb 2015
    Hi,
    Thought this might be useful for you.
    This company makes a TUTD module that works via CAN BUS and also displays gear information via any screen you like.
    https://www.facebook.com/video.php?v...933147&theater
    cheers
    Mar 2017
    31
    Hi, what ended up working here. Seems people are getting TUTD to work with NO BCM and WITHOUT the corvette tune.
    Jul 2016
    Manchester,NJ
    Hey guys ive been reading alot and my biggest problem right now is my HP tuners seems to be missing options. i need to set to hardwired to get tutd to work
    Jul 2016
    20
    Does anyone have any updates?
    Sep 2017
    16
    Any updates?
    Feb 2010
    400
    Any updates? Seems when poeple figure this out they don't feel like posting what's actually required to fix it??
    Mar 2017
    31
    Anyone figured out how to get tap shift working properly without the BCM or the corvette tune? I keep hearing about it being done this would really help with the truck swap combos!
