Page 1 of 9 12345 ... LastLast
Results 1 to 20 of 173
Thread: PCM Identification Thread
    Oct 2007
    Crawfordville, FL
    2,456
    With all the new Ford updates as of late, a lot of people are confused as to which PCM type to select in order to read their PCM. Hopefully this will help.
    For 2011-2014 V8 Mustangs and F150s, use Copperhead
    For 2011-2014 V6 Mustangs and F150s, use ESYS
    For 2015 V8 Mustangs and F150s, use TC-1791
    For 2011-2014 Ecoboost F150, and 2015 Ecoboost Mustang, use TC-1797*
    For 2017+ F150 3.5L Ecoboost, its a TC-277,
    For 2017 F150 2.7L Ecoboost, its a TC-1797,
    For 2017 F150 V8, its a TC-1791
    For 2018 Mustang, F150 with 5.0L or 2.7 its a TC-298
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,456
    If you have a vehicle in question, post here and I will tell you what to select in order to read it.
    Eric Brooks
    HP Tuners, LLC
    Dec 2014
    5
    HP newby ..were do I type in the pcm type?? Im working on a 2015 mustang..?? thanks
    Oct 2007
    Crawfordville, FL
    2,456
    When you read the car, if the software does not recognize the OSID, you have to choose which controller (aka PCM) to use in order to read it. Pretty sure I have all the 2015's covered at this point, so you shouldnt have to select.
    Eric Brooks
    HP Tuners, LLC
    Dec 2014
    5
    Ok , It doesn't give that option .. It says unable to validate VCM. please send a vcm Suite info log to [email protected] I have done that...Thanks
    Jan 2011
    VENEZUELA
    126
    i sended a 2012 explorer file a long time ago any update i know you guys are very fast but please i need to tune that truck
    28,312
    Quote Originally Posted by noskim View Post
    sounds like you are using 2.24, not 2.25 which is what Eric is referring.
    Advanced Tuner sarg's Avatar
    Aug 2011
    Atlanta, GA
    305
    2002 Focus SVT with a Blackoak ecu.
    Aug 2012
    17
    I need to tune a 2013 Ford Raptor 6.2 engine, the 2.25 support this truck??? and do I have to do something to select the model, ecu version, etc????
    thanks
    Oct 2007
    Crawfordville, FL
    2,456
    You need 2.25. If we have already created a definition for the strategy that is in the truck, you don't have to select the PCM type. In case you have to, you would select Copperhead.
    Eric Brooks
    HP Tuners, LLC
    2007 Expedition
    This is the error message I am getting.
    Reader Upload Request x7F Negative Response Code
    Bill at support suggest I try reading it out as a silver oak. However it is automatically selected as a spanish oak.
    Copy of VCM Suite Log.
    Hardware: 0121
    Firmware: 0116
    PartNumber: 0000006220
    BuildDate: 8/8/2007 12:00:00 AM
    InterfaceOnTime: 00:05:12.0650000
    ROM: 00 3F 00 81 00 01 00 FC FF
    Config: CC 88 00 00 00 40
    System Info: F7 00 00 00
    Comm Errors: 00 00 00 00 00
    SPI Info: 20 15 A5 5A 4E 41 00 00
    VehicleConnectedTime: 00:05:12.0650000
    DetectedProtocols: CAN
    SAE J1979 Info: CAN, 500 kb/s, Standard 11 bit, TCM: 7E9, ECM: 7E8
    Spanish Oak 2048K, Ford, OS: INBHCKB.HEX
    2007 Ford Expedition EL, 5.4 L, 8 Cyl
    ECM: 7E8, CAN, PIDs: 43
    VIN: 1FMFK17507LA02637
    Calibration IDs: INBHCKB.HEX
    Calibration VNs: 0D8A4466
    Pending Trouble Codes: P0420 - Catalyst System Efficiency Below Threshold (Bank 1),
    Scanning Methods: Mode 0x01 Functional, Mode 0x01 Physical, ISO 14230-3 Mode 0x22 None, Mode 0x23 4x2
    TCM: 7E9, CAN, PIDs: 16
    Calibration IDs: 8L1P-7J104-AB
    Calibration VNs: 0E1C89E8
    Pending Trouble Codes: U0100 - Lost Communication With ECM/PCM A,
    Trouble Codes:
    Regards,
    Brian Turner
    Dyno Tune Motorsports
    Dyno Tuning and Remote Tuning For Ford - GM - Chrysler Vehicles
    Click Here For Dyno Tune Motorsports
    1988 Ford Mustang GT INCON Systems TT
    331 Cubic Inches - Corn - 808 RWHP 918 RWTQ
    Oct 2007
    Crawfordville, FL
    2,456
    Quote Originally Posted by Mobile Chassis Dyno View Post
    2007 Expedition
    Hardware: 0121
    Firmware: 0116
    Trouble Codes:
    Send the info log to support and we will get it sorted. The OSID is probably still associated with Spanish Oak.
    Eric Brooks
    HP Tuners, LLC
    Houston Tx
    77
    Trying to read 2014 shelby how do i get the 2.25 beta? And what do i need to select to read.
    Oct 2007
    Crawfordville, FL
    2,456
    Quote Originally Posted by etm351 View Post
    Email support at hptuners dot com, with your interface serial number and Bill will add it to your customer center.
    You will likely not need to select the controller, since we have already defined all of the GT500 operating systems, but it uses the Copperhead ECM.
    Eric Brooks
    HP Tuners, LLC
    Any planned support for a 2011 Fiesta? Not exactly a hotbed for tuning, but I despise how my daily driver is tuned from the factory. I have 2.25 (older version, I'm not sure if there's anything new) and tried reading the ECM last fall without any success.
    Oct 2007
    Crawfordville, FL
    2,456
    It is planned. We have a PCM on order, just waiting on it.
    Eric Brooks
    HP Tuners, LLC
    That's great news Eric. If you're looking for any testers of the platform once you get that far, please keep me in mind.
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    How's the EEC-V support coming? I have a 2003 Marauder I'd like to tune. Is 2.25 capable of reading it?
    Oct 2007
    Crawfordville, FL
    2,456
    Quote Originally Posted by 96gt4.6 View Post
    It will read it, but very slowly. Probably 45 - 60 mins to read. We have to make some firmware changes to fix the speed, as reading these older vehicles uses a different protocol than the newer ones we support. At some point we will support EEC-V, but I have no ETA.
    Eric Brooks
    HP Tuners, LLC
    Apr 2007
    Los Lunas, Avondale
    79
    Looking at buying a 2008 Ford Explorer Sport Trac 4.8, is this supported in the beta? The Mustang, Explorer SUV, Trucks, Crown Vic and Vans are listed in that year.
    I have the beta but haven't had a chance to plug into the car to see.
    2002 NBM WS6
    APS F-BODY TWIN TURBO KIT
    317 Heads
    60# Mototron Injectors
    HPTuners tuned by Sean@Solid-Technology, Abq NM
    610 RWHP DYNOJET on 7.9PSI
