Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: 2008 Ford Mustang Shelby GT500
    Quote Originally Posted by Eric@HPTuners View Post
    Done, it will be in tomorrows build of 2.25
    Could they be added to FPAF0A3? 2007 GT. I'm having trouble getting my cat monitor to run as well.
    Feb 2008
    Pittsburgh PA
    112
    I have a 2008 GT here with an on3 turbo kit and I'm having a hell of a time getting any of the readiness tests to set. Not sure if I just have it setup wrong or not.
    2010 Camaro SS LS3 - Heads, Cam, Whipple 11psi 756whp 663wtq 93 and meth
    Feb 2008
    Pittsburgh PA
    112
    OS is FPAN054
    Feb 2008
    Pittsburgh PA
    112
    never mind i'm dumb, just found it. must have happened when i updated the other day.
    Quote Originally Posted by BoostedYards86 View Post
    Did you get the catalyst monitor to run? If so could you tell me what you changed? I don't see cat failure ratio under engine diag. Just updated.
  6. #26
    Oct 2007
    Crawfordville, FL
    2,442
    Quote Originally Posted by Exley View Post
    The parameters aren't in every definition. Email your file to support and I'll get it added faster.
    Eric Brooks
    HP Tuners, LLC
  7. #27
    Will do. Thank you!
  8. #28
    May 2015
    I have a 2009 GT500 and ever since my long tubes were installed and the car was tuned, I am still getting the P0153 and P0133. The tuner has set the delay multiple times and the codes continue to come on. What are the stock values? May just need to start all over again.
  9. #29
    Nov 2015
    OK, parameters added into a few of the Copperhead definitions, including those that asked for it above.
    You will want to raise all these values to the max. ;-)
    Has anyone ever defined what these four parameters are and how they work?
