Page 3 of 13 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 254
Thread: ** MPVI Firmware v118 *ANNOUNCEMENT* **
  1. #41
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Downloading now!
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  2. #42
    Sep 2002
    Chicago, IL
    6,397
    the version you are downloading has a serious bug in it...
    We got this guy Not Sure, ...
  3. #43
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I'll have to play with it some more when connected to a car
    The first thing I've notice that I don't really like is the lack of a "Primary Table" field when setting up histograms. I used to use this to quickly get units/break points setup to match up with what I need in VCM Editor.
    Is there a way to do this that I'm just missing?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  4. #44
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by Keith@HPTuners View Post
    Well.. what is it?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  5. #45
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Yes that version crashed while I was connected using it.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
  6. #46
    13,621
    Do we need to call the Orkin man?
  7. #47
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    Anybody else get this in 2.25 trying to flash?
    I've already sent an email to support, just thought I would post up here as well. 2.24 doesn't seem to have this issue.
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
  8. #48
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I couldn't get it to flash on mine earlier either.. worked fine when I went back to 2.24 though
    (I don't recall that particular error though)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  9. #49
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Quote Originally Posted by Niemer View Post
    Post your file please. This is unrelated to the firmware update, usually an issue with the file itself.
  10. #50
    fecadefa
    615
    It would be very helpful if you told us more details about the error.
  11. #51
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by Engineer@HPT View Post
    Sorry, it will be a day or two before I can get more info
    Going from memory.. sometimes it gave me an error about not connecting to the vehicle, then sometimes it would get a little further then eventually give me some kind of time out error about the ECM not responding. I reset the interface / switched car on and off several times trying to get it to work
    I then switched back to 2.24 and it worked first try. I tried to use both the scanner and editor, neither worked
    Sorry, I know from an engineering level that isn't going to help much. I'll get some screenshots in a day or two when I'm back at the car
    Are there any log files I can send you to help once I am back at the car?
    (it was def. NOT the data integrity error the previous user had)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  12. #52
    Jul 2012
    371
    I sent the .hpt file(s) and debug.dat file to Bill the other day, he should have forwarded them to you.
  13. #53
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    For whatever it's worth, I downloaded the latest version yesterday and it wrote/recorded fine.. so not sure if it was just a fluke or if I got a newer build where my issue was resolved.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  14. #54
    Sep 2002
    Chicago, IL
    6,397
    This new firmware breaks the MPVI standalone data logging functionality.
    We're working on a solution. It will likely require another firmware upgrade.
  15. #55
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Well, that explains why that didn't work the other day
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  16. #56
    Jul 2012
    371
    Same, bummer. Hopefully a solution is found soon.
    On another note, the latest build fixed the data integrity error I got on an earlier one.
  17. #57
    Sep 2008
    1,668
    I always forget to click disconnect in the scanner...and I've grown very used to remembering right before I write calibration only in the tuner...and then watching it say required security delay not expired and waiting 10 seconds...so I've been pleasantly surprised to see this doesn't seem to happen to me anymore since the firmware update and using 2.24.
    For the people getting errors working on Gen 4 GM V8 cars using 2.25...why not just use 2.24?
    2023 Durango Hellcat
  18. #58
    Mar 2010
    Texas Hill Country
    3,299
    because using 2.24 isn't going to help improve 2.25.
    2.24 is history. use it if needed.
  19. #59
    Same here, Writing fails, scanner crashes.
  20. #60
    Nov 2012
    5
    please we desprate
