Results 1 to 13 of 13
Thread: Copperhead - Tip In Spark Retard
    Oct 2007
    Crawfordville, FL
    2,583
    The way the logic is done in the Copperhead ECM for Tip In Spark Retard is a little different than earlier years, in fact there are differences between how the 11-12 Mustang handles it, compared to the 13-14.
    In this screenshot, you can see how it is handled in the 11-12s.
    If the Airmass/Event exceeds Airmass Enable, the PCM infers a tip in has taken place, and removes the amount of timing specified in the Spark Borderline Tip In Modifier vs. RPM
    In the 13-14, there are a few more parameters.
    Spark Tip In Borderline Retard vs. RPM vs. Load is how much timing is removed from the borderline spark calculation.
    Spark Tip In Pedal Delta Enable vs. RPM vs. Load is the % pedal change to be considered a tip in.
    Spark Tip In Load Delta Threshold Enable vs. RPM vs. Load is the load increase to be considered a tip in.
    Spark Tip In Events vs. RPM is the number of spark events to keep the retard amount pulled.
    Spark Tip In Events Delay vs. RPM is how many spark events to wait before removing the timing, once a tip in has taken place.
    Tuner Blown383's Avatar
    Sep 2011
    New Mexico
    160
    Is it safe to just zero these tables out and not have timing pulled in tip in? Is this considered a form of torque management?
    2007 Ford Mustang GT/CS: RGR 322 3v - JPC Intake - Vortech YSi-B - Magnum T56 XL - Built 8.8 - Full Suspension
    2008 Ford Shelby GT500: VMP Gen 2 - ATI 15% - SCJ TB - Full Bassani Exhaust - Full Suspension - Upper Pulley - Meth Injection - JLT 127mm
    Oct 2007
    Crawfordville, FL
    2,583
    Quote Originally Posted by Blown383 View Post
    Yes
    Is that common to do (zero out the tables) on Fords?
    Total Masshole.
    2013 F150 FX4 Supercrew Ecoboost - STOCK
    2013 Mustang GT Premium - Lots of Mods, 424 RWHP SOLD
    2009 Cobalt SS/TC Black Sedan
    227whp/224wtq Stock. Dejon CP, K&N SRI, Forge BPV, Catless, BadMab Catless DP, MPx 3" Catback, HPT Tuned 328whp/425wtq. SOLD
    2004 GTO Pulse Red 1 of 512 - R.I.P. 5/31/09
    Oct 2007
    Crawfordville, FL
    2,583
    Yes, pretty common tune change. In the older (EEC and Spanish Oak) PCMs, it was done another way as well, and it was common to just disable the logic.
    Eric Brooks
    HP Tuners, LLC
    Mar 2013
    45
    wht is the difference in year model?
    Dec 2005
    222
    You can also work with the threshold points to control when the tip-in is signaled. With more aggressive combinations such as positive displacement blowers, it may be desirable to retain the tip-in retard but delay the trigger until heavier tip-in conditions are met. Working with the thresholds, you can tailor when the logic is activated. The thresholds are in terms mass per intake event.
    Jeff Chambers, Owner
    CRT Performance, LLC
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Performance Parts, Service and Dyno Tuning Specialists
    Feb 2006
    Rancho Santa Margarita, CA
    906
    If electronic throttle tip-in mgtm is disabled, would it also disabled the tip-in spark ? or do they work independently from each other ?
    Oct 2007
    Crawfordville, FL
    2,583
    Seperately
    Feb 2006
    906
    Ty sir.
    Feb 2006
    Canada
    1,972
    Nice tid-bit, the V6 for 2013 is set up like the earlier Mustang Eric posted. I was wondering if we should just 0 that table or use the Airmass Tables, good stuff and thanks guys...
    2000 Trans Am WS6
    Oct 2007
    Crawfordville, FL
    2,583
    Quote Originally Posted by MMGT1 View Post
    Either way will eliminate it.
    Quote Originally Posted by Eric@HPTuners View Post
    should i max out the value or put everything to zero to disable tip in spark management ?
