Results 1 to 8 of 8
Thread: 5.3 to 6.0L performance swap, need help with the tune please
    Jun 2014
    18
    replaced a 5.3L with a performance 6.0L (ordered through oreillys) (specs for engine are listed below) . using same injectors. I already changed the tune on it, but all I done was change cylinder size from what is was to the size of the 6.0l bore. It runs like crap. what all do I need to do in my tune to compensate for this new engine?
    the sheet it came with does not tell me any about the cam lift, all it says is that it will have a "noticeable idle"
    horsepower: 460 @ 5600
    torque: 470 @ 3800
    block: seasoned OE LQ4/6.0L iron
    Bore/Stroke: up to 4.040 x 3.622
    displacement (cu. in): up to 371
    Crankshaft: OEM GM 24 tooth reluctor wheel
    Rods: stock GM
    Pistons: Hyperneutectic / 9.5:1 Compression
    Rings: Moly
    Camshaft: Hyd. Roller
    Cam Specs: Customer Performance Grind
    Cylinder heads: OE Aluminum 71cc 2.00/1.55
    Rocker Arms: OE Powdered Metal 1.7 ratio
    405
    2,382
    Knowing the cam specs would help a lot. And not the lift but the duration and LSA. Runs like crap is not helping either. What is the problem? Idle? Off idle cruise? WOT? Some? All? What you posted appears to be a completely stock file. Even the cyl vol. The stock 24lb injectors will probably be to small and it the cam is very big or with a narrow LSA, idle could be an issue with a stock torque converter.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,023
    from the sheet given it looks like ve and maf require remapping, the simplest will be turning ve off, (although I do recommend fully tuning ve as driveability is much better with ve enabled) turn ve off at 400 rpms re-enable ve at 300 rpms and work the maf table. This should atleast get you running. The idle tables will require considerable work. these things should get you on the road however a full tune is in order
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Oct 2014
    SE KANSAS
    11
    I'm about as new to this as it gets, so this is as much a question for the experienced guys as it is an answer to the OP. Wouldn't a copy/paste of a stock 6.0L tables be a much closer starting point? Pretty sure that's where I'd start anyway, should get drive-able and you tweak from there.
    I must be shorter than I think, because it seems I am CONSTANTLY get'n in over my head!
    Builds:
    55 Bel Air Sedan - 5.3, 4L60, 3.73 Posi
    72 K5 Blazer - 5.3, 4L60, Passenger Drop 241C
    85 K10 Truck - 98-Vortec 350, 4L60, Passenger Drop 241C
    Coming Soon : 68 Chevelle Convertible to get 5.3/4L60
    Pics will be available IF I ever get around to it!!!
    Jun 2014
    18
    The vehicle runs right now , it just doesn't idle well . Seems to clear up with giving it throttle , but will die after it comes back down from WOT. I don't think this can is a whole lot bigger than stock . But again I don't know and the build sheet does not say
    Jun 2014
    18
    Quote Originally Posted by mcarmack View Post
    Also yes the file I attached is from before I edited anything
    Advanced Tuner Ranger6202's Avatar
    Oct 2013
    Wyoming
    346
    I'd start by disabling your VE, start with MAF tuning just to get it running consistently and see what else may be acting up (like your dying after WOT). Oh, and i probably wouldn't be doing WOT using 24# injectors on a motor rated @ 460hp. You're gonna need about #36 injectors. And how about posting a scan for us too....
    Jun 2012
    225
    Here are the cam specs.
    It's a Howards cam with Duration 269 / 278
    Duration @ 50 216 / 224
    Lift 551 / 551
    LSA 114
    110 CL
    Change your engine type and cylinder volume to a 6.0 under engine general to get you started. Then you could copy the idle airflow table and spark tables to get you started. There is a 2004 ss silverado stock tune in the tune repository you can look at.
