Originally Posted by
Weston@HPTuners
I'm assuming you're in "Segment" mode... YES If you press the icon to the left of the coordinate boxes, you can set each position based on where you're currently located. This allows you to walk to the start line, and/or the finish line, and set the position there.
Do I press on the little blank box with my finger? Doesn't seem to work? Sorry if I'm just being dense?
For Autocross, you may consider just leaving the start coordinate blank, which will cause it to auto-start upon movement from a stop. If your event's timing starts at a point after the vehicle's actual start, then that's when you might want to set a specific start coordinate. Timers are 10 - 20 ft from start.
You can optionally set the finish point to make the timing automatically stop at that point, and then the overall session will stop about 15 seconds after. Obviously, a smartphone's GPS accuracy will not perfectly match the high-precision laser timing system used in most autocross events, so the run times calculated here are an approximation that will depend on the quality of the GPS data and start/finish coordinates. The main objective is that it records the data and video to cover the time span of your session, which it does very well.
I have Dual 160
Android phone - motox gen 1
If you don't opt to set the finish point, then the session just ends whenever you press one of the navigation tab buttons other than "Record".
