![Quote](images/misc/quote_icon.png)
Originally Posted by
hiddeous
Paulo,
Turbo logic won't work on an NA PCM as it will look for the Boost pressure sensor (and the NA Pm doesn't have the third connector for boost control) You'll need to edit the load axis on the fuel and spark tables to reflect the higher load from boost. Just click on the axis and you will be able to edit the load points and then use the turbo Tmap.
You'll need to run and external boost controller. I'd recommend an Eboost2 with and tach driver providing and RPM input so you can map set points against rpm
