ba/bf n/a wheel speed
i have been playing with ba/bf auto 4 speed
i have tryed to dyno it in 3rd gear but it stop when the wheel speed goes past 204 klm
is there any other way around it or can we change to go past this.
what is the best gear to use 2nd or 3rd
how do you stop it it from timing out when it gets to 204klm in 3rd gear
i can run it out to the rev limiter in 2nd
any advise i have had a couple do it change the limiter for speed still does it
thanks
Set the RPM and Torque values to their max for the throttle based speed control under DBW. These limits aren't often realised in a turbo car as the limiter is set to 230+.
thanks mate
i have had several looks and i can not find it iam using the beta 2.25
i have gone throw every table and can not see it
thanks
Are you in Perth iirc? I can talk you through it if need be.
What tag is this under?
I had a na6 on the dyno and was not going past 180 @4800 rpm, i changed the vss limit 2 to 230 to no evail.
230? Re-read my post above.
