Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 139
Thread: This will help make sense of the Mapped Points on the newer Fords...
    Oct 2007
    Crawfordville, FL
    2,436
    This video shows the weighting factors in action. You can see what percentage of each table is contributing. At idle its running soley off the Mapped Point 0 tables. So 100% of the spark is pulling from that table. The torque calculation values are being pulled from Mapped Point 0 as well.
    As the RPM comes up, you can see that a combination of different tables are being used to determine the actual spark, torque, and speed density values.
    Eric Brooks
    HP Tuners, LLC
    Apr 2015
    CO
    99
    Awesome! Looks incredibly valuable.
    Jun 2008
    Tyler/Longview, TX area
    746
    That's cool to see it in action! Thanks Eric!
    Dec 2014
    49
    Quote Originally Posted by Eric@HPTuners View Post
    Subscribed..
    Nov 2009
    All Around
    3,149
    freakin awesome!
    Oct 2014
    8
    Oh yeah!
    Nov 2007
    MI
    686
    thanks for the visual. sounds nasty btw
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
    Dec 2008
    on the Dyno
    1,825
    Nice!!! Looks like it's scanning fairly fast as well! I've not got to play with anymore Coyote's since the 2.25 scanner was released.
    Located in Central Kentucky
    ShorTuning
    Jun 2008
    746
    I'm trying to learn how to use the scanner. Is there some secret mojo needed to get the mapped points to read?
    Oct 2007
    Crawfordville, FL
    2,436
    Quote Originally Posted by txcharlie View Post
    These parameters are DMR, which means we request it based on memory address. In EVERY operating system, the addresses are different. I have DMRs in only a couple of the OS' currently. I will be rolling it out over the next several days.
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,436
    More scanner teasing...
    Eric Brooks
    HP Tuners, LLC
    Apr 2015
    CO
    99
    WOW! Ford is becoming a first-class citizen!
    So much awesomeness!!!
    Jun 2008
    746
    Sounds like a lot of work! Thanks for making it happen!
    Oct 2007
    Crawfordville, FL
    2,436
    Lastest 2.25 has DMRs for FSFR0. Please test it and report back.
    Eric Brooks
    HP Tuners, LLC
    Tuner Blown383's Avatar
    Sep 2011
    New Mexico
    157
    Eric,what's the logic behind using mapped points vs the way they did VCT with Spanish Oak?
    2007 Ford Mustang GT/CS: RGR 322 3v - JPC Intake - Vortech YSi-B - Magnum T56 XL - Built 8.8 - Full Suspension
    2008 Ford Shelby GT500: VMP Gen 2 - ATI 15% - SCJ TB - Full Bassani Exhaust - Full Suspension - Upper Pulley - Meth Injection - JLT 127mm
    Oct 2007
    Crawfordville, FL
    2,436
    Quote Originally Posted by Blown383 View Post
    With a single cam doing VCT, the intake and exhaust valve events move together, so mapping in the software is straight forward.
    Since the intake and exhaust cams on the newer Fords are controlled independently of each other, a way to model the infinite number of cam position combos is needed, and this is the way Ford decided to handle it.
    Eric Brooks
    HP Tuners, LLC
    Feb 2006
    Canada
    1,963
    It'll be nice to figure this one out properly. I have been into a boosted 6 that uses the same lay out for timing tables. I have changed every MAP Point from 55 up to give timing we want in PE and then blended back to existing timing in each table. For now its working just fine, but this would make things not so "sketchy" for sure!
    2000 Trans Am WS6
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    That's a huge help, Eric. Thanks...
    2009 Cadillac CTS-V 196.7 MPH on the Salt
    Superflow SF600 FlowBench -- Superflow Autodyn 30 Chassis Dyno -- Superflow SF901 Engine Dyno--RaceLogic Emulator -- MikiPro Logic Emulator -- ASNU Injector Flow Bench --
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    Eric,
    Have the Mapped Points been added to OS # KTCP4CZ? 2012 F150 5.0L ECU.
    I can't seem to find them in the Scanner Channel List?
    Thank You!
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
