Page 9 of 11 FirstFirst ... 567891011 LastLast
Results 161 to 180 of 212
Thread: MPVI1 USB driver installation
  1. #161
    28,311
    Quote Originally Posted by KTM View Post
    3)Connect your MPVI interface to your laptop
    4)At this point the driver install will likely fail(it did for me)
    ^Windows doesn't detect the MPVI interface and doesn't attempt to download any drivers, so in Device Manager nothing shown is there....
    when you connect your interface to your pc but NOT a vehicle does the green power light illuminate?
  2. #162
    Sep 2014
    8
    Yes it does
  3. #163
    28,311
    does your pc give off a distinct *ding* when you connect the interface to it ie its recognizing it?
  4. #164
    Sep 2014
    8
    No, That is what confuses me. It acts as if laptop doesn't even notice it being plugged in, but it gets power.
  5. #165
    28,311
    try an alternate usb cable, if that doesn't do the trick email support and we'll have you send in the interface for testing.
  6. #166
    Sep 2014
    8
    I played with a few things and I think I got it working. Device manager now shows under the Universal Serial Bus Controllers HP Tuners MPVI Challen A, and B.
    Thanks so much for the quick replies too! I appreciate it. Nice to know you guys are on here to help people out!
  7. #167
    Aug 2010
    49
    Mine did but I still get the cannot find VCM. &^%$@#$^*&^$!!!!!#%^%$
  8. #168
    Aug 2010
    49
    Ill try the device manger trick next. This started after I used another friends computer to tune his car.
    Now it will not see my VCM on both of my cars
  9. #169
    Jun 2013
    7
    I Seem to be having the exact same problem KTM had. I was tuning my car, all of a sudden, it started giving me the "Interface not found"? And now, I can't see the MPVI in the device manager and when I plug in the interface, it does not recognize or show up in the device manager?
    KTM, how did you sort this out?
    Everyone else, any suggestions?
  10. #170
    Sep 2002
    Chicago, IL
    6,397
    Sounds like it could be a bad USB cable.
    We got this guy Not Sure, ...
  11. #171
    Jun 2013
    7
    I tried a different cable, no dice...
    I will see if I can find a third cable just in case the second one I tried is also bad, but I don't think the cable is the issue.
    I'm no computer wizard and this is driving me crazy....
  12. #172
    Jun 2013
    7
    So after playing with it, in the device manager, the MPVI shows up as "USB Composite Device" ???? No more Chanel A and Chanel B? Any idea
  13. #173
    Mar 2015
    4
    im in the same situation can't figure it out at all. i see two usb composite device aswell. i also tried a new cable. and no luck
  14. #174
    Nov 2015
    I did everything from step 1 and till the end got my drivers but I cannot find the hptuners screen on the desktop
  15. #175
    28,311
    Quote Originally Posted by tony1985 View Post
    No idea what you mean to be honest, we do not install anything to your desktop.
    Everything our software installs goes to your programs folder.
  16. #176
    Jul 2011
    Camden, Arkansas
    20
    OK... I haven't used my Hptuner in almost a year... I got a new laptop ( I don't have my install disk ) I downloaded everything I saw on the hptuner page... It dings when I plug it up but I can't find the program or use it... what am I doing wrong?
  17. #177
    Tuner 9secZO6's Avatar
    Sep 2007
    On the Bayou around New Orleans
    82
    Quote Originally Posted by TURNEROFFROAD View Post
    you will need to open the programs folder, locate hpt. and from there you can create a desktop shortcut. You can have icons for both the scanner and the editor.
    JOHN
    06 Z06 ETP heads, 244/256 hyd. roller, crower stainless shaft rockers, Kooks stepped race headers,elec. w/p, 160 stat, vararam, ram dual disk, ported intake and t-body, 100 shot spray until the 441 goes together http://www.youtube.com/watch?v=fm1hrBcq63U
    2016 Callaway Z06 a8 3lz zo7
    Heads, cam, headers, 2.3L s/c, 9.5 lower/2.625upper, meth, 103mm t-body,
    Stock high and low fuel system for now (I know right?)
  18. #178
    Jun 2016
    Wisconsin
    3
    Ok, I'm new to this and can't figure it out. I've done everything the instructions say but it still doesn't do what it says it should. After I installed everything and go to the HP Tuners program, it goes to VCM Suite not VCM Editor. Then it has HP Tuners so I click on that and it only has logs and tunes and VCM Scanner options.
  19. #179
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    You aren't being very specific on what you're trying to do.
    What are you trying to do?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  20. #180
    Jun 2016
    Wisconsin
    3
    I got it figured out finally. Sorry for not being specific. I was just getting frustrated. But now when I plug it in to the car it asks what I want to open the program with. And everything I tried doesn't open anything up.
