]Hello I have been out of this for a while I am have an issue where PE does not change no matter what value I put in the blocks. the truck was FI and now is NA. and when I go into PE it wants to run at .7** lambda. no matter what I tell it to. I have read the sticky and changed accordingly with no such luck. I have to be missing something but don't know what. I have even rechecked the MAF to see if that was causing. still nothing cant be ve as it is disabled in MAF tune. I would greatly appreciate any and all feedback. attached is6-19-15.hpt
ok here is the correct log that one was in 2014 when i got hp tuners and was trying to undo what a friend of a friend had done here is the correct log 6-19-15-2.hpl
