Results 1 to 6 of 6
Thread: HPT 2.24 Scanner incorrectly reads KR
    Dec 2014
    13
    A week ago I had issues with version 2.23(beta) scanner. I configured a few gauges, then the scanner crashed, and I couldn't reopen it. I've had the following problem since: I'm suddenly having incorrect KR readings in the histograms. From top to bottom, first couple read 0.1. The next couple read 0.2, and so on, and maxed at 0.7. During the scan, I saw the KR gauge read several times between 2-5 degrees. Anyone know why it's recording this way, or how to fix it?
    28,313
    post your .hpl scanner file.
    Mar 2010
    Texas Hill Country
    3,299
    Did you accidentally click the - (minus) button on the histogram?
    Dec 2014
    13
    I didn't click the minus button.
    28,313
    looks fine to me.
    Dec 2014
    13
    For one, I'm not really getting .3 degrees of KR at idle. Two, it was recording in areas the the engine has never been operated in. ie. grams/cyl .12 at 5200 rpm. I just did a clean install of HPT version 2.24, and now when I clicked on the above file, it shows correctly. Yay! There must have been a corrupted file in the other install. I have yet to test the scanner in the car. If I have problems, I'll repost. Thanks!
