Results 21 to 40 of 41
Thread: tuning help..... please!!....
    13,630
    I'd email support.
    Screen shot the error aswell and send it to them.
    May 2015
    28
    I can take a picture but I can't monitor the pcm I can only write over it.
    May 2015
    28
    It's crazy.. it's like the pcm is done. I just don't understand why or how. Ya know.
    May 2015
    28
    I emailed Eric and also asked bill on another post to hopefully get some info..
    Jun 2008
    Tyler/Longview, TX area
    746
    I would try this:
    1. Disconnect negative battery terminal, turn on headlights and leave them on for 20-30 minutes. This clears KAM. Check your battery voltage with negative terminal disconnected.
    2. Turn off lights and make sure all accessories are off.
    3. Connect negative batter terminal.
    4. Load last known good tune, with last known good beta editor.
    If tune loads normally, start car and don't do anything but let it idle for 2-3 minutes. Then turn on A/C and let idle for another minute.
    Good luck!
    Also, you should be on battery with a good charge on your laptop. No inverter powering your laptop.
  6. #26
    May 2015
    28
    OK I'll give that a try.. thank you..
  7. #27
    Nov 2011
    44
    Just a thought. Make sure you aren't connected to the scanner while trying to write a tune. Connected to the scanner via the program. I've done it before lol
  8. #28
    Apr 2015
    212
    My 2013 strategy didnt like some of the spark changes that the 2011 strategy that is in the car runs just fine.
    Copying a calibration from one strategy to another completely doesnt always work for whatever reason. I switched strategies and the car stopped doing this. Its VERY difficult to get it to take a write when it acts up like youre describing.
    Disconnect battery, wait 30-40 seconds and reconnect. then sitting in the car i had to key on and immediately click write on the laptop to get it to take. Ive had the "check charging system" error a handful of times with the 2011 file in the car (the car is a 2013) and a disconnect and re-try of the same file always works.
    Your problem is probably that you're trying to write a file that it doesnt like. When my car would panic, it didnt fail at 74.2%... it would write the whole 100% like normal then have a party flashing lights and all kinds of errors lol.
  9. #29
    Advanced Tuner AKDMB's Avatar
    Sep 2014
    NC
    344
    I have always wondered what happens when the "wait half an hour and try again" method doesn't work. Hope support helps you get this figured out. I assume you already know, but just as a future precaution, never have any doors open or any form of accessory running(even the radio or map light) during the flash.
  10. #30
    May 2015
    28
    No luck 100 percent stock tune after KAM reset still the same..
  11. #31
    May 2015
    28
    The battery VDC was 12.66 everything was off doors closed, write was successful and still the lights are going crazy everything is crazy. Here is something that was different.. the milage was there after the Kam reset then after the stock tune was sent it was all dashes.. I can only write to the pcm. I can't monitor it in viewer beta. It's just jacked up.. I would hope someone at hp can point me in the right direction I mean damn it's not like I changed pcm's... I have never seen this happen with my own 2012 mustang gt ever and I have changed way more things on my pcm then this 2014... I'm not sure what is really the root cause of this but it blows my mind.. is tuning a crapshoot or what.. is this just a fluke???????..... DAMMIT!!
  12. #32
    May 2015
    28
    All in all thanks everyone for the help I appreciate it..
  13. #33
    Jun 2008
    746
    http://www.hptuners.com/forum/showth...CMs-what-to-do
    No one has figured out exactly what causes this. The solution seems to be persistence and to keep trying to flash after a 20 minute break. I believe it would be a good idea to charge your battery to as close to 13v as you can get before you start again.
  14. #34
    May 2015
    28
    OK thanks txcharlie...
  15. #35
    May 2015
    28
    You have been a huge help..
  16. #36
    Jun 2008
    746
    Did you get her going?
  17. #37
    Sep 2014
    N/A
    87
    I have had this happen a few times on some of the older 2.25 versions. Update to the latest beta first. Make sure battery voltage is above 13 for sure with a trickle charger on it while trying to load the tune. At 74.2% the vcm does one last voltage check and if too low zooms the rest and leaves you in a failed state (from what I've read). My friend changed out his battery and it never happened again.
  18. #38
    Jun 2008
    746
    Quote Originally Posted by Yagermeister View Post
    That's the best explanation I have heard.
  19. #39
    Sep 2014
    N/A
    87
    Can't find the thread but I had saved the quote..."This is a very common issue caused by a voltage check the ecu does during the tuning process. It checks at the beginning right after erasing the ecu and it checks at 74.2% through the writing process. If it fails either then the ecu locks up. Ive had a few customers have this issue. It has nothing to do with the tune, software or the ngauge. Its fords fault lol."
  20. #40
    Sep 2014
    NC
    344
    ^^^ I agree, best explanation I have heard. Happens just as easily with SCT devices too. Could somebody build a voltage test into the software that checks voltage before the flash and warns you if it is too low ?
