Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 83
Thread: Off Board Programming 2010+ E38 with SPS
    Jun 2012
    30
    Thanks..
    I'm just going to order one..
    this problem has caused me more grief than the cost of the adapter..
    Quote Originally Posted by hefe33 View Post
    Thanks..
    I'm using the EFI professional harness and cannot program off board. I sent Mike at EFI Connection an email about this and never heard back.
    Jun 2012
    30
    what error do you get?
    and what are you doing exactly?
    like reprogram via tis2web .. ect...
    Forget the exact message, but was "off board programming detected" and would not allow me to continue.
    Just reprogramming original/updated OS via TDS.
    I've done many modules off-board recently. ECMs, radios, FPCMs and all have programmed just fine with TIS and the MDI.
    There is an MDI-2 coming down the pipe since GM just released the new software to support it.
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
  6. #26
    Jun 2012
    30
    Quote Originally Posted by erick_e View Post
    I haven't seen that error yet.....
  7. #27
    Forgot I wrote it down on a piece of paper.
    "M6413: Off-board Programming Detected" and will not allow me to continue; it just restarts.
  8. #28
    Jun 2012
    30
    very interested in what the people in the know say about this
  9. #29
    Dec 2006
    Birmingham, Alabama
    156
    I do it all the time. I have a homemade bench top harness that I made up, but I also run a BCM on it.
    I can flash the ECU or BCM bench top with a J2534 pass thru and GM SPS.
    It doesn't seem to make any difference what BCM I have hooked up it still will flash the ECU. But if you have a BCM or TCM on your bench top harness you have to have all of them plunged in or jumper out the Can high and low wires as they run thru each module.
  10. #30
    Jun 2012
    30
    if I am reading this right, the BCM allows it to pass the "off board programming detected"?
  11. #31
    Dec 2006
    Birmingham, Alabama
    156
    I wouldn't say that. I just so happen to need to program BCM's so I added it to my cable. Unless something has changed you should be able to program any GM ecu with a valid license to GM SPS and a off board programing J2534 Tool.
    I did run into some errors when programing after trying to load the wrong calibration into a E38. I thought 12625455 ECU was for 2009-2010 and after putting a 2010 calibration in it, it bricked.
    Here is what I found for E38's
    2007 19210738
    2008 12612384
    2009 12625455
    10-13 12633238
  12. #32
    Quote Originally Posted by rpmextreme View Post
    That's the problem we are trying to address, or at least I am. Using a Bosch Mastertech MVCI and EFI Connection stand alone harness I am unable to program using TDS.
  13. #33
    Dec 2006
    Birmingham, Alabama
    156
    I just programed a 2013 E38 using a OTC J2534 and GM SPS, homemade harness with a BCM. Worked fine. Im not using AC delco TDS so I know its not exactly apple to apples.
  14. #34
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    I think people using SPS won't have issues.
    http://www.dsxtuning.com
    Just say no to bull s***.
  15. #35
    Jun 2012
    30
    well, I ordered my benchtop programming adapter from EFI Connection, and I use SPS, so we shall see
    I will report back
  16. #36
    Mar 2006
    25
    Any Updates ?
  17. #37
    Jun 2012
    30
    sorry.. yes..
    the problem I had MUST have been in my homemade adapter
    once I plugged in the EFI Connection "pro" adapter it worked like butter!
  18. #38
    Mar 2006
    25
    Awesome !
  19. #39
    Jan 2009
    Spokane, WA
    480
    Was just gonna say, I've never had issues with MDI and SPS either. More than 90% of the stuff I do is on the bench. Sometimes I don't have the engine harness or bench harness, so I end up just making something with pins and still don't have any issues.
  20. #40
    Jun 2012
    30
    the weird part for me was that HPT worked fine with my home-made adapter, but not GM stuff...
