Page 1 of 20 1234511 ... LastLast
Results 1 to 20 of 397
Thread: 3.5 EcoBoost Advice?
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    Novice tuner on the 3.5L here, looking for any helpful hints on tuning them.
    I have a very good amount of experience in the 5.0L Coyote, and GM GEN 3+4 LS setups, however, nothing in the 3.5L Eco with direct injection.
    Any pointers on what AFR to shoot? I've heard direct injection seems to require a little leaner AFR. Also, ANY advice before I begin on how to adjust boost would be much appreciated! It appears the tables go off of Turbo Airflow, or the likes.
    Thanks in advance!
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
    Jan 2013
    22
    Yep, your not going to find anything here about 3.5 ecoboost. It's been 1 year since support has been added for this platform and .....
    -Still can't scan for check engine codes
    -Doesn't contain any scanner data for transmission
    -And plenty other things.
    To many platforms are being added before any prior ones are finished.
    Most are just buying other tuners
    Aug 2008
    Kansas
    489
    Indeed, the scanner side of things has a ways to go, but the guys at HP have been pretty keen about getting us some engine parameters. Seems just like yesterday there were barely any engine parameters in there that were scannable.
    Currently, I use my dealer level tool for datalogging, then make changes with HP.
    I'll keep this thread updated as I progress through the Eco tuning
    '17 Whipple'd S550
    Quote Originally Posted by 96gt4.6 View Post
    Interested in sharing any input on your tuning process of these? I haven't done any Eco's either, but have a co-worker that wants his done. Would be a good one to learn on as it doesn't have to be done in one day. I have an IDS and Verus for any dealer level logging if that is what you are getting at.
    Thanks in advance!
    Oct 2007
    Crawfordville, FL
    2,466
    Quote Originally Posted by splashgtp View Post
    You can check DTC codes....
    Eric Brooks
    HP Tuners, LLC
    Jan 2013
    22
    Quote Originally Posted by Eric@HPTuners View Post
    I'm going to have to have to double check. I'll probably need to send a file in. I'm updated and get a handful of codes thrown (pulled though another scanner) everything time I read a file. 2011 F-150
    Aug 2008
    Kansas
    489
    Quote Originally Posted by Gerrot View Post
    Thanks in advance!
    I will keep the thread updated as I progress. Yes, I use an IDS for logging purposes. It's invaluable to have all the PIDs during tuning. HP has everything I need for the Coyote's as far as engine tuning, and Eric has been a big help in getting those up to speed for us. It will only get better with time on the scanner. Seems literally just like yesterday where we could only tune the Coyote's but the scanner was HIGHLY limited and ID'd as a Silverado even, but it got us some basics. Amazing how far and much has been added even since then.
    I should get under way with my '15 in the coming weeks by the looks of it, and will share my findings.
    '17 Whipple'd S550
    Aug 2008
    Kansas
    489
    Make sure you are using the latest BETA. Items are added to it almost daily. When tuning any Coyote/EcoBoost setup, I always download the program again before I start.
    '17 Whipple'd S550
    Great! Read the PCM today, but it's all F**cked up to say the least. The values are all over the place, not sure if I did something wrong, or that's just the way it is. Lol.
    Aug 2008
    Kansas
    489
    I'd email support with your exact concerns and see what they say. My '15 works fine. I have read the tune, and all the scanner data looks great:
    '17 Whipple'd S550
    Feb 2006
    South Carolina
    1,525
    Is your ECU stock or has it been tuned by another product?
    Scanner worked great for me too. Just the stuff in the VCM editor that was definitely off.
    Scanner worked fine for me too.
    Capture 2 by Lee Jacobson, on Flickr
    Quote Originally Posted by ElecTech View Post
    Never been touched before. Co-worker just bought it and it was a one owner truck. Previous owner was a 65 year old fella, that traded it in for another new. one. So I highly doubt be did anything to the PCM on it. Lol.
    Feb 2006
    South Carolina
    1,525
    Probably just a bug in the definition file. Email support your file so they can check it out.
    Aug 2008
    Kansas
    489
    I agree, there is something going on there no doudt. Here's the same tables in my '15:
    '17 Whipple'd S550
    Emailed [email protected]. Hope they can figure it out.
    Jul 2015
    Florida
    19
    Ive done extensive dyno tuning / logging of the 3.5, approx 12 hours.
    Found many things to adjust, and things not to. Cranked boost up to 19psi and yes have control over throttle
    Just a word to the wise, Ive had issues with the latest nightly update, lost channels I needed to see to tune properly. Also, in the the log Gerrot shared KR isnt logged. BIG no no. Stock tunes have a ton of KR
    dlgransion,
    I haven't done any tuning yet, just was sharing that I could log properly, but the file was not correct. Willing to share what table you adjusted? Also, interested in hearing what you all log, or would like to see what you all log if you are willing to share your Config with us.
    Thanks!
