Anyone got a good 6.4L procharger base tune i can take a look at?
you will probably not find that here at all.
having a procharger is not the problem, its the fuel system and what else you have installed with it
Remote Tuning [email protected]
I have a built base file. But wanted to look at some of the spark tables and torque tables. Anyone?
Google advanced search:
http://www.hptuners.com/forum/showth...-installed-but
Did you look at that tune? I'd already found that one. Timing tables looks way to aggressive and not scaled.
I have a procharged tune file posted on the limp mode wont rev thread if it helps, Smitty
if ur getting limp mode its probably coz your map settings aren't dialed in properly
Bader Norris
MEP Tuned
Telephone: +965-55446651
Email: [email protected]
also possibly the "lighting bolt" sign could show up
Get the dealership to flash the ECU with a M6 program.
Bader Norris
MEP Tuned
since its a 08 and they didnt have a manual trans option yet would it still work though? I was told to do that I would need to swap to a 2009 ecu and that it was configured different, would have other issues to overcome? The dealer is going to be clueless about swapping the wrong year flash into it from past experiences with them since they go by vin numbers and such.
