DIC date wrong after flash
I'm working on a 2005 GTP. Last time I flashed it, the date on the DIC was reset to the wrong day.
Any ideas how to fix this?
I have a 2004 GTP that is one day off due to a programming error, and I have always been told that the radio holds the date information?
________
Starcraft 2 Replay Cooltycho
KSef, I see it's been a while since you posted this. I do not know the answer to your question, but I wanted to ask if you knew anything about this calendar. I just put an aftermarket radio and now I don't have the day and date. I can enter it, it takes it, displays it for a while, and then shortly goes to just dashes. It is retained somewhere because if I try it again, that same input is retained. Also, the day name does not ever come up like it used to. At all.
I was trying to search for information on this, and your question seems to be around the same topic. It always seemed like it looked up (or calculated) a day name after the date input. And now since my radio is gone, it may not have the information. i.e. Inline with your statement about radio holding the date information.
I would appreciate any info you may know about this.
BTW, did you ever gey your problem figured out?
