Results 1 to 9 of 9
Thread: 2007 Corvette -E38 PCM - Max out MAF 67.7 lb/min
    Mar 2013
    43
    Greetings! I will start by saying I am not an expert tuner. I have been tuning on my corvette for about 1.5 years. I recently did a motor swap and went to a long rod forged 370ci motor with a custom grind cam. I did it for a couple reasons, one of which is because I was curious to see what the motor would put out. Secondly, I roll race my car and being able to hold gears longer and staying in the high RPMS while still making power would benefit me. The motor was built to spin to 8000 rpm and it has a custom grind cam by Brian Tooley that was spec'd for this purpose. The car is naturally aspirated LQ4 bored to 4.030 with a stock 3.62 stroke. The compression is about 11.1:1. It has a 105 MAF housing,LS7 MAF, LS3 injectors, ported stock TB, MSD Air Force Intake. I am on here asking because I could be heading down the wrong path and one of you could save me.
    The issue I am having I am maxing out the MAF lb/min PID. In my scanned data you can see it hits a certain point and flat lines. During the runs the car pulls hard until top of third gear and then levels out. It acts like its maxed out the injectors, but the duty cycle is at 95%. I know I need to get bigger injectors and will order some once I figure out how big to go, but maybe something I am doing in the tune is making it look like they are maxed out. Do you think the two thing correlate?
    I have attached my files for review. If anyone wants to look the tune over, I'd take that input as well. Like I said I am not a pro. Be blunt if you must, every bit of input helps. If anyone thinks I should let a pro tune it, say that as well.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Upgrade to the enhanced operating system.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Mar 2013
    43
    Okay, thanks. I just upgraded to the enhanced OS. I believe I saw to use a 2005 C6 VE table as a starting point?
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Try it and see what happens.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    yes, you can use that as a rough start, but the real benefit I think dave is pointing you towards is the extended MAF table. your upper frequency is now over 15,000hz and airflow about 135lb/m vs the 11,500 ish and 67.7lb/m it was...
    Mar 2013
    43
    Thanks Tommy. I am moving in multiple directions at once. I am also wanting to tune my VE, as the car is on a MAF only tune right now.
    Tuning Addict
    6,903
    I don't know if this applies to 2.24 or not, but if your using beta watch out on the enhanced OS's right now... Especially if your getting up above a 100 map level where boost enrichment could possibly kick in. Fought one today where it was hitting my boost enrichment map setting of 90kpa and it would automatically lean out the air fuel to 18 or just flat out kill the motor like I had switched the key off? Set the BE to 255 and was able to continue... Of course that was only after wasting time on it trying to figure out what was going on... Just saying if you all of a sudden have weird issues, there might be a simple explanation.
    ~Greg Huggins~
    Mar 2013
    43
    Thanks for the heads up
    Nov 2009
    All Around
    3,149
    doing a blend would be best. your MAF will be able to handle more Lbs of Air with OS upgrade.
