Awesome stuff Jet!!
Awesome stuff Jet!!
Thanks joe i think your set up is around this hey ( 476kw/638hp ) ?
FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
SUBARU BRZ ......AVO TURBO KIT coming......soon
VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
FG XR6T UTE M6
GTX3582
Garrett 12psi actuator
Port & flap
X-FORCE 4 inch dump & system
Processwest stage 2 intercooler kit
4 inch air box
Battery relo
ID1000's
Walbro intank
Valve springs
98 fuel
Stock clutch
Stock engine
401rwkw @ 17 psi flat, very happy with the tune and outcome of this beast
http://youtu.be/YKVLaN5bj68
Be careful of the carbon monoxide jet, causes brain damage and inability to tune from what I have seen.
Have You been looking at your tunes again then terry ?
BA XR6T T5
Wog cooler
Street airbox
4inch dump
Twin 2.5 cat back
60lb dekas
Intank pump
263rwkw @ 13psi on 98
http://youtu.be/Ls3oGXLlfZ4
If I told you I have a BA XR6T T5 with stock everything except a k&n drop in filter and 42lb delphi's 278rwkw @9psi, would you believe it?
Why wouldn't I ?
Cause I didn't!
Certainly would believe it as my Territory with a debung, 12psi and 42lb Bosch 968s made 275 awkw so a tad more than 278 rwkw and that was with a CAPA mail order tune Must admit my graph did not look as smooth as Jets though.
Just say your reply muz, then get cracking it should, just fiddle the dyno!
I just really enjoy the big torque lump that comes in so soon from e85 and so little boost!
How's the Haltech Darryl?
There's a reason this car only has the power it does and that's because it's very worn in every aspect so it wasn't about making numbers but giving it a bit of a hit with a chunk of safety built in
Don't get wrapped up in the numbers, it will send you crazy lol
I actually like it. I also got an old BA UniChip for the loom so I made the Interceptor plug and play. It worked very well and I was able to get my mechanic to find a wire for when the LPG was running so the two maps was really helpful. It is off the car currently and was intending to do it as a winters project once I get the car on the dyno and work out where the timing for LPG and 98 will be and then put that into the Interceptor. It was fun doing doing a program to take the MAP alterations for fuel get correct spark due to load altering. All in all a great find by you
At this stage I have the two injectors close enough for me to concentrate on the new turbo (basically a GTX3576R with an extended tip wheel) so hopefully similar power to what I have but with enough down low to tow the horses (the GT3582R takes too long to get up to speed when you put it behind a Territory towing a couple of extra tonnes).
Nice man! I towed two horses behind my XR6T, trailer weight approx. 1700kg on BBQ gas and holy shit the fuel consumption (or lack of). I've got a Dodge Ram with the 5.9 Cummins for those duties (which is now supported by HP yip yip!). The old Coon has taken a back seat as a result! Aiming for 550-600rwhp and 1000-1100lb/ft out of the dirty old diesel
Diesel's heyyyyy
Had a look today myself
Hey Jet got an old one of those (2006). Made 93rwkw and then I got a steinbauer for it and they got about 115rwkw out of it with better fuel economy and response. Very interested in your outcomes
Yeah Jet, diesel is unfortunately in my veins. Have been driving big jiggers for 15 years now! Makes me sound old lol
I've got a Borg Warner S480 with billet compressor wheel to hang under the Cummins original Holset he351 in a compound setup
Grab a 2.8 diesel Colorado, strap it to the rollers and go over it with HP Tuners. Come over to the dark side, it's sooty!
