Page 15 of 17 FirstFirst ... 511121314151617 LastLast
Results 281 to 300 of 334
Thread: EQ <> VE Version 3.5
  1. #281
    Advanced Tuner Bluecat's Avatar
    May 2006
    Catlettsburg, Ky
    407
    Quote Originally Posted by Monty View Post
    Have looked all over the place can't seem to find the file anywhere.. maybe i wouldn't even be able to use it once iv found it, will it work for tuning Main VE or just GMVE ? As this is after all the (Gen 4) area of the forum .. I am Gen 3 man, a search brought me here.
    The program will only do you any good if you are trying to tune the newer family of ecm's that lack normal ve tables. As far as finding a copy of it, the last version I released (v2) is still properly linked in its respective thread. As far as V3 and V3.5, I neither posses or condone any of the Ktoonsez versions as he was never supposed to release my code with his changes. Your on your own there.
  2. #282
    Jul 2007
    16
    Visit this thread to get VE v3.5:
    http://www.hptuners.com/forum/showth...563#post311563
  3. #283
    May 2006
    Catlettsburg, Ky
    407
  4. #284
    Apr 2010
    11
    I've notice a glitch in the newest version. Previously, with the EQ<>VE tool running....if you right-click-copy on the wrong HP Tuners table then the BlueCat tool would "flash red" and not import data. It would only "flash green" and import a correct table. It knew what was the expected format of data.
    The new version will import any table that you right-click-copy which means the wrong data could be imported to create the Virtual VE surface in the BlueCat tool.
    BlueCat this EQ<>VE tool is great! Thanks for all the effort programming it.
  5. #285
    May 2015
    17
    Ayone know where there is a step by step guide on how to use this tool?
  6. #286
    Apr 2009
    25
    Quote Originally Posted by RealQuick View Post
    http://www.camaro5.com/forums/showthread.php?t=196696
  7. #287
    Advanced Tuner jpb1972's Avatar
    Mar 2015
    New Jersey
    271
  8. #288
    May 2008
    Chandler, AZ
    537
    Anybody still using this? I started tuning using 2.25 beta today and see that the hooks are not working so was going to update it if there are still people out there using it.
    ____________________________
    2008 Convertible Corvette
    Haltech CAI | Kooks Headers and X-pipe | 227/231 .613/.617 lift 115 LSA CAM | Tuned to death
  9. #289
    Mar 2005
    Hendersonville TN
    161
    I still use it.
    Bryan
  10. #290
    May 2008
    Chandler, AZ
    537
    Cooool, just updated first post.
  11. #291
    May 2008
    Chandler, AZ
    537
    ************** UPDATE #3 1/28/2016************
    Just an update for a few of you guys out there that requested some stuff:
    1. Recompiled main U.I. with newest Visual Studio 2015 using .NET framework 4.6.1 (see links below for runtime files)
    2. Recompiled DLL with newest Visual Studio 2015 for more speed in equation generation (see links below for runtime files)
    3. Updated hooks for getting equations/tables in and out of HPT for 2.25 beta's.
    4. Changed the thread selection from a multiplier to just a static number of threads to select from.
    ENJOY GUYS!
    Here is the link to the new 5.0 Version
    http://www.mediafire.com/download/w4...x94/EQ_VE5.zip
    .NET 4.6.1 Runtime download:
    https://www.microsoft.com/en-us/down....aspx?id=49981
    Here is the link for Microsoft Visual C++ 2015 runtime files if you need them (select the x86 version even if you have a 64 bit machine, the DLL is written in 32 bit for speed reasons).
    https://www.microsoft.com/en-us/down....aspx?id=49984
  12. #292
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    Is that supposed to say 2015 or 2016?
  13. #293
    May 2008
    Chandler, AZ
    537
    2015, there is no developer studio 2016 yet from Microsoft.
  14. #294
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    I meant the "UPDATE #3 1/28/2015" part
  15. #295
    May 2008
    Chandler, AZ
    537
    Oops, didnt even catch that, its 2016 and I just fixed it.
  16. #296
    May 2008
    Chandler, AZ
    537
    ************** UPDATE #4 02/12/2016************
    1. Made some optimization tweaks to the dll.
    2. Added compatibility for Gen 5 vehicles!!!!!!!!!!!
    3. Added VE Table format for Gen 5 vehicles.
    ENJOY GUYS!
    Here is the link to the new 5.0.5875.22995 Version
  17. #297
    Jul 2013
    15
    hey guys, when I try to generate equation constants the program keeps crashing. also should I be concerned that its suddenly populating the DoD cells when they were previously 0 if I send equations back to hp tuners? this is on gen 5 car.
  18. #298
    May 2008
    Chandler, AZ
    537
    Quote Originally Posted by jfdmas View Post
    Did you extract the whole zip file to the same folder? What Windows are you running? Did you try to set a different "Thread Count" (try the "Generate Equations with 1 thread" option)?
  19. #299
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    Is there a reason for not just using the built in VVE editor in HP Tuners?
  20. #300
    May 2008
    Chandler, AZ
    537
    No, why?
