WOE, we have help files. I have some reading to do. ...and at a glance they look great.
2006 LS2 Corvette
Automatic
2.56 gear
600 HP Edelbrock E Force Kit
No other mods
Help files are still in development... but should be released publicly next week.
We got this guy Not Sure, ...
Does this work when adding new channels (i.e. shows what is available for that vehicle profile) or only when adding parameters to charts/graphs?New beta up.
In the Parameter Selector form, there is a new Gear with a green checkbox icon. You can use this to filter out parameters that aren't backed by channels.
Ok, I am getting a bit frustrated with myself as I can't figure out why I am having do much trouble with filtering in 2.25....I need another set of eyes (and brains :-)) to help me. Its the same filter I use in 2.24 and again it is a log imported over to 2.25 from a 2.24 scan. In my mind, this should only show data from FTC cells 1-15 and when the AFR commanded is below 14.2...no?
Here are the files.....I can pit up a screen capture but am on my Surface and coping screens is a bit convoluted
Thank you in advance
Ed M
ES Test channel.Channels.xmlEricS VE.Layout.xmlAEM WB.MathParameter.xmlAEM WB Err.MathParameter.xml
[email protected]
here is the screen shot
Ed M
[email protected]
The help files have been updated, here: http://www.hptuners.com/help/vcm-scanner/
Mowtown, you also need to post the log in question.
Sorry, the attachment limit of 5 gets me every time :-)
eric log of final tune rev Q. 01-28-2016.hpl
[email protected]
The layout you posted doesn't include the graph in question.
[email protected]
works for me.
Also, there's no need to do avg(0). That's the same as without the avg() fn.
I don't understand because now it is working for me as well. I did start over in the scanner by loading all Default channels/tables/charts and then re-loaded the files I sent you and it seems to be working now. I am sorry I wasted your time.
Is there anything that needs to be done when you bring in a new Layout/log or when modifying filters to get them initiated...much like in 2.24 where we had to Load Data each time the filter was modified?
I like the Channel selected filter in the latest version. Makes setting up the tables much easier and verifies the required Channels have been selected.
Also last question, is there a way yet where we can modify the Channel table based on the current loaded Channel and Layout files? Always says I have to be hooked to the car or define a profile which I see is still in development.
Thank you again
Ed M
[email protected]
You can just select "Vehicle/Offline Profiles" and you should be able to create a channel config off of any of the previously connected profiles. You have to have connected to the vehicle at least once. If the person you are helping is using 2.25 and shares the ".os.udp" file for a particular vehicle, that might allow you to build for a car you haven't touched.
Jaime
[email protected]
You'd still need to manually edit the VCM Suite.cfg if you wanted to access a custom off-line profile.
This will be more user friendly in the future.
Reading my 2001 Workhorse RV GM 8.1L, the new Beta scanner shows it as a 4.3L v6. Is this ok should I ignore it?
File attached.. 2016_1-31 Beta_Read.hpt
ZL1 Wheels/Tires
