Results 1 to 12 of 12
Thread: 2014 Ls3 kennybll 3.6 liter
    Mar 2013
    45
    We have a 2014 LS3 we installed a Kb 3.6L and ID 1000 along with long tubes and a nick Williams 102mm Tb.
    Installed a drop in aeromotive fuel pump assembly for this car and we cant get the p023F code to go away. Don't see it in the Dtc area anywhere. We installed the fuel sensor back on car and got that light off this is a full return style system boost referenced mechanical regulator. Any suggestion on the Dtc?
    Tuning Addict
    6,873
    I assume complete fpcm delete has been done? How is your setup wired?
    ~Greg Huggins~
    Mar 2013
    45
    The kit came with its own wiring harness assembly so nothing on car is used anymore! Basically standalone system! Like a fore kit but it's Aeromotive.
    Mar 2013
    45
    The fpcm is still on turned all codes off I could. But the system is not being used with a pulse width modulated system any more.
    Mar 2013
    45
    Steady 58 psi system 1:1 under boost
    Tuning Addict
    6,873
    You have to unplug and remove the fpcm for codes to kill it Should be good after that... Something about it still having the ability to communicate ticks things off...
    ~Greg Huggins~
    Mar 2013
    45
    Thank you brother
    Tuning Addict
    6,873
    No problem, it's always amazing how the simplest of things like unplugging a connector can cause us the biggest headaches
    ~Greg Huggins~
    Mar 2013
    45
    I agree!
    Dec 2008
    on the Dyno
    1,825
    What are you guys doing to kill this code but keep the fuel pressure sensor working so that injector delta pressure can be monitored still?
    Located in Central Kentucky
    ShorTuning
    commanded fuel pressure needs to closely match actual. tough with boost/vac reference, not so hard if you leave it unreferenced....
    Dec 2008
    on the Dyno
    1,825
    Basically you must use the fpcm to use the built in fuel pressure sensor... Meaning the only way to keep the p023f code from popping up is to power one of the fuel pumps with the fpcm. Not sure how the current output will play with the Walbro F90000274 but we are going to find out.
    ShorTuning
