Page 16 of 17 FirstFirst ... 6121314151617 LastLast
Results 301 to 320 of 334
Thread: EQ <> VE Version 3.5
  1. #301
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Just curious. Seems like that would be easier. I didn't know if there was a feature or something that this software has that HPT does not have
  2. #302
    May 2008
    Chandler, AZ
    537
    I think people use this that want all the configurability. Like letting it re-define the boundaries, I don't think HPT does that. Also the level of precision can be tweeked in this vs. static in HPT. Its all just user preference in the end
    ____________________________
    2008 Convertible Corvette
    Haltech CAI | Kooks Headers and X-pipe | 227/231 .613/.617 lift 115 LSA CAM | Tuned to death
  3. #303
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Gotcha. I do like how it adjusts the boundaries for you to get a better fit
  4. #304
    Tuning Addict
    6,903
    Is there still a way to rotate the axis so the ve table matches the one in HP exactly? I honestly miss being able to correctly modify the borders and map points like the bluecat program did. Thanks for updating this....
    ~Greg Huggins~
  5. #305
    May 2008
    Chandler, AZ
    537
    Your welcome. Yes you can flip the axis, open the "Table_Dim.txt" file and flip the 2 lines below the name of the format you are using
  6. #306
    Tuning Addict
    6,903
    Quote Originally Posted by ktoonsez View Post
    I'm apparently doing something wrong here. I tried to save it and save as every way that I know how, but every time I close the Table_Dim.txt file, it reverts right back to what it was... I guess it's not editable?
    Next question.... You seem to know the HP program really well. Is it possible for you to make a tool that would change "background" tables that HP's not wanting to mess with right now? Baro update just to name one? You can PM on this if you wish.
    Thanks Again,
    Greg
    ~Greg Huggins~
  7. #307
    May 2008
    Chandler, AZ
    537
    Thanks Again,
    Greg
    Lol, I screwed u up. I forgot about the leading character on the line with the format name, it is a capital "N" or an "I". Changing it to the opposite (N to and I, I to an N) will flip it for you. Which format are you using? I might have to make an update for the Gen 5 one to work properly. And no I cannot change the "background" tables
  8. #308
    Aug 2013
    australia
    364
    Is there any reason why the blue cat Ve surface looks different to the hpt Ve surface.
  9. #309
    May 2008
    Chandler, AZ
    537
    Quote Originally Posted by will15 View Post
    They will look identical if your axis are identical between HPT and this.
  10. #310
    Tuning Addict
    6,903
    OK, I changed the I to an N in the file... This did get the rpm to go across the top of the VE table like it does in HP, but the map/baro pressure ratio changed to "0's" and "1's"? I copied the table from the file and pasted into the HP table and it wasn't "completely" different, but especially up in the higher rpms and load areas it was way under what it should have been. I hope that makes sense - not the best at explaining things???? This was a gen 5 table. Haven't tried any of the others yet.
    ~Greg Huggins~
  11. #311
    May 2008
    Chandler, AZ
    537
    I figured you were trying to use Gen 5, ya thats going to need a program update since I had to do special things to get that working on the other axis, I will need to do more edits to make it work on the other.
  12. #312
    Tuning Addict
    6,903
    Oh, OK
    Then probably just something trivial, but how to you change the "bar" setup? Not as straight forward as the original with having the simple click on tabs, but does a lot more, so I guess I'll just have to "learn"
    ~Greg Huggins~
  13. #313
    May 2008
    Chandler, AZ
    537
    ************** UPDATE #5 03/05/2016************
    1. Made some fixes so you can flip the axis's of Gen 5 VE table (As requested from GHuggins).
    ENJOY GUYS!
    Here is the link to the new 5.0.5908.14064 Version
    http://www.mediafire.com/download/ka...mo5/EQ_VE5.zip
    .NET 4.6.1 Runtime download:
    https://www.microsoft.com/en-us/down....aspx?id=49981
    Here is the link for Microsoft Visual C++ 2015 runtime files if you need them (select the x86 version even if you have a 64 bit machine, the DLL is written in 32 bit for speed reasons).
    https://www.microsoft.com/en-us/down....aspx?id=49984
  14. #314
    Tuning Addict
    6,903
    It will require hand modification of the units in the axis, but damn near spot on to what HP pulls up in their editor, plus this one actually correctly changes the boundaries... At least this is what I observed while playing with the gen5 version... Very Nice. Thank You....
    ~Greg Huggins~
  15. #315
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I do really like it changing the boundaries..
  16. #316
    im using version 5.0.5908 with my l76 holden and when i go to generate equations it just comes up with "unhandled exception has occurred in your application"
    where am i going wrong here?
  17. #317
    does hpt verson 2.24 not work with version 5 of eq to ve?
  18. #318
    Ive noticed that it the help button it says that you need to " in order to copy/ send the ve table to hptuner you must have ve LoAltd table open in a temporary ls3 file.
    what is a temporary ls3 file?
  19. #319
    May 2008
    Chandler, AZ
    537
    Quote Originally Posted by andrew1988 View Post
    Does it happen immediately when you click "Generate"? If so it sounds like you didnt install the C++ runtime. It works for me in 2.24, 2.25 and 3.0.
  20. #320
    May 2008
    Chandler, AZ
    537
    You want to have a temporary file open because it is going to copy and paste things in and out of that file and you do not want to accidentally leave those values in the tune. So the temporary file is just some file you do not care about and will never flash to the car.
