Page 59 of 87 FirstFirst ... 94955565758596061626369 ... LastLast
Results 1,161 to 1,180 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #1161
    Dec 2008
    on the Dyno
    1,825
    Keith can you guys add back the list to describe voltage=what for the mpvi inputs. I used this the most in the old scanner to keep my wideband reading exactly what it was supposed to across the full 0-5v spectrum. The slope isn't linear and my wideband outputs 1.0v, 4.0v and 0.0v upon startup and I use that to dial in what is displayed in the scanner.
    Located in Central Kentucky
    ShorTuning
  2. #1162
    Sep 2002
    Chicago, IL
    6,397
    We will eventually, however, i believe your ECM has serial output, and we're adding serial input for many devices... you'll want to use that over voltage input anyway.
    We got this guy Not Sure, ...
  3. #1163
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by Keith@HPTuners View Post
    I would however I don't believe the ECM AFM1600L has the serial output. Guess it's time to upgrade :-/
    ShorTuning
  4. #1164
    Tuning Addict
    6,876
    Quote Originally Posted by LSxpwrdZ View Post
    I was told by ECM that you could use an analog to serial converter, but they weren't guaranteeing anything... Not sure if my lambda pro will work either? Haven't used it yet to verify... I know it's $5500 for one of theirs that does have a serial output :-/ Can't afford that, especially after getting the lambda pro when using 2.24......
    Keith the scanner is back to acting screwy after todays update - or atleast for me. Won't log the air mass while scanning - just logs ignition timing or knock across in a straight line, then you replay the log and it will move through the cells correctly, but won't display any values in them???
    ~Greg Huggins~
  5. #1165
    Dec 2008
    on the Dyno
    1,825
    Yeah that basically defeats the purpose since that is basically what the MPVI Pro cable is doing itself. The AFM1500 has serial output but I do see they offer a LambdaCAN now so I'm wondering if that may be an option as well to incorporate the wideband stream via CAN bus. CAN wouldn't help out older cars however...
    ShorTuning
  6. #1166
    Tuning Addict
    6,876
    That's true. Just wasn't sure what you were after. I tried to get a 1500 just for the serial output when i got the lambda pro, but they discontinued them for some reason?
    ~Greg Huggins~
  7. #1167
    Jul 2015
    23
    AFRerror/wideband tables don't match on the column axis data.
    They seem to have the columns from the timing tables and not the VE table.
    Is RTT coming back soon? Really needed it the other night on my truck. Can I flash back to 2.24, as I found the installation disc still in my laptop?
  8. #1168
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Then change them.
    Only the last 2.24 version will work, it's highly unlikely that's on the cd you found
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  9. #1169
    Apr 2014
    NC
    64
    I tried this, but my current file was modified in 3.0 and I can't pull it up in 2.24.
    Quote Originally Posted by Dave926 View Post
  10. #1170
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by XDR View Post
    Do a read in 2.24
  11. #1171
    Apr 2014
    NC
    64
    I read in 2.24, then tried to flash in 2.24 and got a cable credit error. I may try again tomorrow, running a 1 bar sd os, so not sure if that was my issue.
  12. #1172
    Jul 2015
    23
    Only got my cable back in September. .....
  13. #1173
    Mar 2007
    DFW Texas
    306
    If it is not the latest 2.24, it will not be compatible with your updated interface. There is a thread floating around here on this.
    1961 C-10 5.3 NV3500
    2007 NNBS ECSB 4.8
  14. #1174
    Apr 2014
    NC
    64
    Quote Originally Posted by mcfarlnd View Post
    That could be it, I have 2.24.949.
  15. #1175
    28,303
    Too old to work with the newer 120 version of firmware.
  16. #1176
    Advanced Tuner Atomic's Avatar
    Jun 2008
    455
    It would be really nice for you guys if the "error reporting" would send when a connection is available instead of having to do it right then. So if it crashes and you dont have a network connection, it will save it and send it next time you are connected and the software is active.
    I can consistently crash the software by "divding by zero" if I restart logging while the engine is running.
  17. #1177
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    It will let you save a copy of the report if you don't have a network connection, though it has to fail to send twice first.. and then you have to send it in manually. I understand your point though..
  18. #1178
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    532
    I take it 2.24.75 is too old?
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
  19. #1179
    Dec 2008
    on the Dyno
    1,825
    2.24.1170 was the last version of 2.24 I believe. If you have a two digit ending then its really old...
    ShorTuning
  20. #1180
    Jun 2009
    N. GA
    532
    I see there is no choice between write calibration and write entire. I was using 2.24 on a GM, 3.0 now on a Dodge.
    What is it doing when Write is chosen in 3.0?
