Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
Thread: E40 ECM scaling for 160-190lb injectors
  1. #41
    u mean the ones under open closed loop "open loop gains" so lets say I multiply my STOIC by 2 I need to open those tables and do the same
  2. #42
    thanks guys found it
  3. #43
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    It's the engine-->fuel-->general "Stoich AFR" in "Air Fuel Ratio" table
  4. #44
    Feb 2013
    4
    Do you do the same for E38?
  5. #45
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yes double stoich/half IFR will work on e38's. Cut the IVT terms in half also
  6. #46
    Feb 2013
    4
    Ok I have E38 PCM which only goes to 63lb/hr & not 127lb/hr. The injectors supplied are ID1700's running 42psi so 160lb/hr.
    Do you think this should work:
    IFR divide 2.6 = 61.5lb/hr
    Stoich x 2.6 = 38.2.....wait I can only goto 32stoich!!
    Any idea's?
  7. #47
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah the double/half thing only works to the point that you max out the stoich table unfortunately, so around x 2.17
  8. #48
    Feb 2013
    4
    And doing the double/half method along with the old rescale method will just be way too hard I think. Sounds like it needs new PCM that can do 127lb/hr with smaller injectors..
  9. #49
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah that's a bit much. I'd probably just start over if I was going from rescale method to double stoich method. If you were only 10% off from getting to the right injector flow rate then I'd just go with it, but you're going to be further off than that with just the double stoich method
  10. #50
    Nov 2005
    Houston, TX
    3,968
    Correct. It's very few things.. stoich, injector flow rate, IVT terms. That is it
    I'm not following what the IVT terms represents and why it should be halved.
    Bill Winters
    Out of the LSx tuning game
  11. #51
    Nov 2005
    Houston, TX
    3,968
    Quote Originally Posted by trd800 View Post
    I've had to do both. I did the rescale of the entire tune way back before the double stoich method was around. Then I went from 1k to 2k injectors so then I doubled stoich.
    Bill Winters
  12. #52
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by 5_Liter_Eater View Post
    They are coefficients that are used when calculating intake valve temp, they should be cut in half when using the double stoich way, otherwise the IVT ends up being something stupid high. I assume it thinks you're running really lean since you have a stoich AFR of something 29+ but don't really know the details of how it's calculated.
    They are under fuel-->general, "IVT Terms". There are two tables, one of the is typically 0 so you can ignore that one. Cut the other one in half
    Will it really make a noticeable difference? Heck if I know.. it probably will for transient fueling but I doubt anything will go boom if you don't do it
    You can thank DSteck for getting us access to this one
  13. #53
    Nov 2005
    Houston, TX
    3,968
    Well I'll find out soon as my tune is pretty lined out now so when I half the IVT terms I'll see if it makes a difference.
    Bill Winters
  14. #54
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    That will be interesting. To me anyways
  15. #55
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    My theory is somewhere in bowels of the IVT equation is an element pertaining to fuel mass and its ability to modify thermal changes to the valve vs ECT or something. The IVT Terms must be the keys to the crypt and when we cut the fuel mass in half, so must we change a variable to bring it back.....and Dave figured that out...Thanks man
    Again, this is just MHO..
    Ed M
    [email protected]
  16. #56
    Tuning Addict
    6,882
    Uses them for cold engine desired ratio (adders, multipliers) and transient fueling that I know of.
    Doesn't the instrument cluster outputs not need to be halved as well when doing the double stoic trick?
    ~Greg Huggins~
  17. #57
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah you do need to mess with that.. I don't have access to that one on my E40 so I always forget about it. Something about fuel density I think it's labeled?
    Good news is I get 800 miles per tank
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  18. #58
    Jun 2011
    Montreal, Canada
    758
    I started using the double stoich method before anyone talked about halving IVT. I didn't see any change when I did do it later on, but it could be effecting something that I just didn't notice.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
  19. #59
    Nov 2005
    Houston, TX
    3,968
    Seemed to lean out my tune quite a bit. Particularly in the smaller pulse width areas
    Bill Winters
  20. #60
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    That is interesting. Though we'll probably never know why..
