Results 1 to 9 of 9
Thread: Thermostat adjustments
    Nov 2014
    42
    Just curious what everyone is dropping there low, medium, and hi speed fan settings to with a 180 tstat. Vehicle is a '14 Jeep SRT. Thanks in advance.
    Tuner Pector55's Avatar
    Nov 2015
    Dover, PA
    186
    My car is a 5.7 - 2013 Challenger RT - Auto 5 but I run a 180* and here is what I have:
    2013 Dodge Challenger RT Plus - Shaker
    Feb 2016
    431
    14 Jeep SRT uses PWM controlled fan.
    Found in System/Fans/Control by ECT/PWM desired ECT - just set it to desired temp depending on thermostat used.
    Low/med/high has no effect on these vehicles.
    Quote Originally Posted by JasonHD View Post
    Nov 2014
    42
    Regardless of what I change, after a day or so, I still get a P0128 code. Is there something in the tune I'm missing, or do most just disable this in the DTC's?
    Advanced Tuner uarperformance's Avatar
    Apr 2007
    Largo
    265
    Did you set the thermostat test to its highest temp and yes you can shut the code off
    Nov 2014
    42
    Guess I'm not seeing where thermostat test is in the tune.
    Dec 2014
    Palmetto, FL
    874
    Since thermostat is suppose to open at 180?F, then you can set fans temperatures to 180?F.
    But the engine will most likely run most efficient at a bit higher temperature tho. Finding what temperature is most efficient is going to take some time to figure out. But 190?-210?F is where I would target to have the temperature controlled.
    Mar 2024
    3
    OP did you get it figured out?
    Jan 2022
    972
    fan tune is very complex
    you must use native values and really, to get the most from it, the entire tune needs to be tweaked, not just the fan temps
    i first adjust those to get the thing to run at 180
    then i go thru the tune with a fine tooth comb - data logging in between every adjustment along the way
    [email protected]
    don tanklage
