Results 1 to 20 of 28
Thread: V3 e40 WILL write config on EFI Live COS
    So long story short..
    I was tuned on EFI live, I moved, rebuilt engine and had it re-tuned on HPT at a new shop (I requested HPT).
    Bought HPT myself to make some changes and noticed that I could not do a write entire / full write to commit the changes I wanted to make.
    Contacted support who said v3 WILL NOT DO a full write to the e40 and to go back to 2.24.
    Loaded up 2.24 and it reads the tune from the car and will save it but wont open it up.
    Contacted support again / provided tune and diag logs..
    Turns out the shop I used had v3 and it wrote the config even tho it was EFIlive custom OS not HPT! (FI application here so HPT would have needed 2bar SD).
    Now Im stuck with EFI live custom OS with a HPT config on it and cant do a full write. Sounds like I get to dealer flash the thing and start all over again?
    /end rant.
    Tuning Addict
    6,889
    Is there a reason why your needing to do a write entire?
    ~Greg Huggins~
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    Was wondering that too
    Yes. There are several things that when flashed that do not work.
    #1 the main VE table.
    #2 the car wont enter OL SD. A few of us have tried. Same table changes work on other e40's that dont have the mix match.
    No way HPT is going to support flashing EFI live COS.
    The thought of tuning one on the other seems like a really bad idea to me.
    Sep 2002
    Chicago, IL
    6,397
    If it opens in VCM Editor, it's supported.
    The parameters you listed do not require a write entire.
    We got this guy Not Sure, ...
    Wow. OK!
    So I should just gi back to v3 and open support cases for things that don't work?
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Quote Originally Posted by MP_ View Post
    3.0 will work fine.
    Since I have an e40 as well and won't do a write entire either . How do I get 2.24 back?Already emailed support with no answer yet and this seems to be a issue with no fix.
    Tuning Addict
    6,889
    Your car uses virtual VE, same that efi live uses and modifies... You may not have a 2bar OS upgrade even available for your vehicle... Go under edit - virtual VVE - should open up your VE table... You still fail the MAF the same ol' way... You can completely "0" out your maf table and log MAF status if your unsure if it's in VE mode or not - if still using MAF - engine won't run for obvious reasons...
    Then you still need to put it into open loop, but this is entirely a waste of time - use fuel trims to tune VE while in closed loop and have a separate grid setup for logging air fuel error - just take what you need from each to modify your VE table... This isn't that hard. If you still have problems, post the tune so we can look at the setup to give guidance
    ~Greg Huggins~
    2 bar is available for the e40 most of the time. but I cant do a full write or even get to that in v3. Thats why I was told to go back to 2.x
    As far as I know there is no "virtual" VE for the e40. Its just the VE tables. I believe there is a difference with the e38 vs e40 but I could be wrong.
    This is the kind of stuff thats missing (boost enrichment)
    first one is mine second one is what I assume it should look like in HPT.
    Quote Originally Posted by v8s10s View Post
    contact support they can get you the 2.24 that will work with the newer firmware in your unit
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    Yeah, E40's have a regular VE table from the factory.
    When you go to the "OS" tab does it have an option to upgrade to a 2 bar OS?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    No that's missing too. I have to do that in 2.24 I guess (according to support) but I can't because of the efi live cos.
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    OS upgrade shows up on my original E40 tune file in V3. Can't do a write entire.. but it at least shows up. I'm not so sure 2.24 will be any different in that regard.
    28,309
    Its an efilive custom operating system, they didn't do it the same way as we did with our custom operating systems, you are limited to THEIR CODE! Comparing one of our custom operating systems to what you are seeing from an EFILIVE custom operating system is like comparing apples to oranges. What is in the ecm is what is there. 2.24 will not help you in this case because it didn't support these operating systems, never will.
    This was more of a warning.. There are still EFI live things in play that HPT isn't touching.
    I dont want EFI live. I want HPT.. So I dealer flash. then 2.4 or can 3.0 add the 2 bar SD COS?
    So I pretty much have to start over.. Right?
    28,309
    2.24 to apply 2 bar then tune it with 3.0
    but to get 2.4 to work I have to dealer flash this thing and start over.
    right?
    Is there a recovery mode to rescue this with HPT?
    Moderator
    Mar 2014
    Raleigh, NC
    6,344
    Do you have the original file, pre-EFILive OS?
    Question for the pros--if he doesn't, can you take another tune with the same OS, change the VIN to match his car, then use that as a starting point to upgrade to 2 bar, etc.? I've never had to do it so I'm not sure.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
