Results 1 to 20 of 25
Thread: Bosch Green Giant 42lb/hr Injector Data
    Dec 2014
    Palmetto, FL
    880
    Hey, I am looking for Injector Data on the Bosch Green Giant 42lb/hr Injectors.
    They are going in Chevy Cruze 1.4L Turbo.
    Dec 2014
    Palmetto, FL
    880
    So still looking for information on these injectors, but also would like someone to give me a bit of advice on the IFR Table for these 1.4L Turbos.
    I would like to know if this is the correct way to scale the injectors for these engines.
    It has the FPCM that controls fuel pressure. So am I supposed to set stock value actual fuel pressure to 58psi which would be the fuel pressure for High Flow mode, Code Engine mode, Default mode, Fail mode, and Cranking mode?
    Still looking for Injector Offset information and some advice on Pulse Correction Tables.
    Dec 2014
    Palmetto, FL
    880
    So after looking at it closer now, that information is not correct.
    The injector calculator I was using is for a Manifold Vacuum based IFR tables.
    So I am also in need of a Injector Calculator for the Fuel Pressure based IFR tables.
    Sorry for all the confusion.
    Dec 2014
    Palmetto, FL
    880
    Wow, I am truly sorry for any confusions. Just been having a off day, I guess.
    Here is a screenshot of how the 42lb/hr injectors are supposed to be scaled in the IFR table.
    It is based to simple math for scaling the injectors.
    New Flow=Old Flow x (New Pressure/Old Pressure)^.5
    Example: 42lb/hr @ 43.5psi, need to know what it is @ 58psi. So take 58 divided by 43.5. Gives you 1.33333. Take the square root of 1.33333. Gives you 1.1547005. Then multiply by 42. Gives you 48.497421. So 48.5lb/hr @ 58psi is your answer. And you just have to go through and insert each pressure into that equation to get your new IFR.
    Once again sorry for all the nonsense.
    Dec 2008
    Nevada
    4,450
    yea good luck with the offset though. the offset data is strictly for the tested pressure and when the pressure increases in the rail it affects the low voltage and short pulse offset data. you will have to get close then tune them in which is going to be a royal pain in the ass given your fueling is based off of virtual correction.
    as i have said to many before you...without having them tested to the desired parameters its going to be a long process. good luck
    Dec 2014
    Palmetto, FL
    880
    Quote Originally Posted by cobaltssoverbooster View Post
    Awesome lol, sounds like I am going to have fun.
    Dec 2008
    Nevada
    4,450
    iirc there was an injector offset guide posted in here. its a document that describes how to do it without sending the data out. just have to search for it
    Dec 2014
    Palmetto, FL
    880
    Thanks, I will search for it.
    Dec 2014
    Palmetto, FL
    880
    So I contacted ZZP asking for information on these injectors. And they replied with......
    The only data I have available is directly on the product page.
    You can just scale the stock injector offset the % difference in size, and they will work properly.
    Is this true or at least a good point to start from? The injectors were purchased from them
    Dec 2008
    Nevada
    4,450
    good point to start from, yes.
    if you need them characterized then call deatschworks...iirc its roughly $80 with a sample injector from your batch.
    Dec 2014
    Palmetto, FL
    880
    Yeah, I was thinking about doing that. Just haven't personally sent them any before.
    So I will call them on Monday of next week. And get a plan together with them on shipping the injectors to them.
    Thanks man.
    Dec 2013
    44
    these injectors flow 310g/min @ 43.5psi. You will have to convert that data to the car's fuel rail pressure. I think i have that spreadsheet. brb
    Dec 2014
    Palmetto, FL
    880
    Quote Originally Posted by kissmy05ss View Post
    The problem with the spreadsheet you attached, it is used for IFR tables that are based off of Manifold Vacuum/Pressure.
    The vehicle I am scaling uses a IFR table based off of Pressure Delta(fuel pressure).
    So that spreadsheet won't help. And I already have the IFR table scaling dialed in. Just looking for the offset, pulse corrections, and limit data for these injectors.
    Aug 2013
    9
    Any luck getting these things dialed in? Got mine installed today, going to start tuning them in tomorrow hopefully.
    Dec 2014
    Palmetto, FL
    880
    Quote Originally Posted by soad85 View Post
    No, I am sending the injectors out to Deatschwerks to have them flow and characterized. Let me know how it turns out for you.
    Dec 2014
    Palmetto, FL
    880
    So I might have found something on these! Would like someone to verify?
    http://www.boschdealer.com/specsheets/0280155968cs.jpg
    Green Giants Bosch 0280155968
    https://performanceparts.ford.com/pa...-9593-f302.pdf
    Green Tops Ford M-9593-F302
    Dec 2008
    Nevada
    4,450
    no...these are ford injector spec sheets. there is a pile of math required to convert it over to a gm specification. i had that data saved already for gt40 swap applications but i knew it wouldn't work so i didn't offer it.
    Dec 2014
    Palmetto, FL
    880
    Is the spreadsheet correct for the 0280155968 injectors? The two spreadsheets show the exact same data?
    Would using this conversion work for converting Ford Data to GM Data with these injectors?
    Ford to GM Injector Data Conversion R3.xlsx
    Dec 2008
    Nevada
    4,450
    those are the bosch green tops for fords. little different than you green bodies.
    you can use the spreadsheet as long as your axis is the same as the results field in the generator.
    you really should send them out and not guess. just because data is out for an injector doesn't mean your set is going to flow close to that data.
