Ive been chasing my tail with what I believe to be false knock. Here is the story.
My car was professionally tuned at about 23-24 degrees on the dyno in march at about 12.6 AFR. Definitely in the safe range.
Mods are LS2 with PRC 66CC Heads, Ls7 cam, LS7 Exhaust, Ls3 Intake Vararam.
I have recently started doing my tuning, I am a novice but I noticed that I was getting knock so Thanks to the help of everyone on the forum I have been able to reduce timing and add fuel.
I also over the weekend switched to a TR6 plug. The car was tuned originally with a TR5
I have taken about 2 degrees of timing out everywhere, and 3-4 around peak torque since then and have changed to a 12.3 AFR
I still get these little blips of knock. It will knock 1 degree and then slowly go back down to 0 or sometimes its only a blip of .4 or so knock. This has happened no matter how much fuel I add or timing I take away.
If I was to slightly desensitize the knock sensors, how would I go about doing that in HP tuners 3.0? I've looked all over and cant seem to find where it would be. If I make any change at all, I want it to be very small to make sure I can still see actual knock if it happens.
I have attached my first tune and also my most recent one along with a log. What do I do guys? I hate taking so much timing away.![]()
