Results 1 to 20 of 22
Thread: ZL1 STFT high on decel
    Advanced Tuner VodeAn's Avatar
    Jun 2012
    230
    I'm working on a modified 2015 Manual Trans ZL1 with an odd issue.
    When coasting to a stop the STFT suddenly shoots to +29% and makes the car run rich, causing the idle to surge.
    Tried running in speed density only, maf only, and blended setup. Also tried with LTFT on and LTFT off, same issue every time.
    Has anyone ran into this issue before? Is there a fix for it?
    Attached is the log, tune and cfg.
    Attachment 59665
    Attachment 59666
    Attachment 59667
    Jun 2012
    230
    You can see the problem at 5 min and 4 seconds in the log
    Nov 2009
    All Around
    3,149
    injectors?
    min inj pw
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Your VVE table drops off a cliff under 40kpa. I'd at least try bringing those areas back up to more closely align with the surrounding areas first
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Tuner dreksnot's Avatar
    Loveland, CO
    147
    I've been battling the rich on coastdown issue too. Would like to know what approach to take.
    2013 Camaro LSX433 with TFS 245cc cat heads
    AGP 65/65 Twin Turbos into BTR Equalizer intake
    BTR 237/247 .610"/.601" 116+5 (10* overlap) cam
    ID-1700x on AGP Fore Triple w/ Flex Fuel sensor
    Cortex EBC | n2mb WOT box | custom anti-lag
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Wonder what fuel trim cell # you guys are in during the rich coastdowns?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Jul 2013
    Clear Lake tx
    423
    so stupid question and feel free to screen slap me here . but isn't DFCO supposed to be taking fuel out on decal...unless you have it disabled of course. sorry guys.
    2010 CTS-V A6, Airaid CAI, 2.4 pulley, ported ls7 throttle body, ID850s, ARH 1-7/8" headers and X pipe, TR7IX plugs, MSD wires, Elite catch can, ZL1 lid and Track Attack HX
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    It should--I've seen mine max out the WB lean when it kicks in
    Jul 2013
    Clear Lake tx
    423
    that's what mine does...O2's stop swinging. i can tap the throttle when its doing it and they will start swinging again normally.
    Loveland, CO
    147
    Quote Originally Posted by JBZ View Post
    The DFCO is getting sidetracked. Yes, it suppose to when meeting the conditions. So, without any consideration to DFCO (had it disabled when tuning fuel), want to focus on how to eliminate the rich on coastdown issue, please.
    Loveland, CO
    147
    Quote Originally Posted by SultanHassanMasTuning View Post
    injectors?
    min inj pw
    Second or third time I've heard of Min IPW as a culprit. So, how to approach troubleshooting/fine tuning. Right now, per ID-1000 data, Min IPW is 0.125ms. Reduce this to something like 0.120? 0.124? My fueling appears good, at least, to novice eyes.
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Make it 0 for testing purposes. Don't think that's it though.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,877
    Engine
    ->Fuel
    --->Open & Closed Loop
    ----->LTFT Idle Cells Thresholds
    Set Enable VSS to 255
    Set Disable VSS to 256
    http://www.dsxtuning.com
    Just say no to bull s***.
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Is access to those new? I don't recall ever seeing them before. Or maybe I just wasn't looking.
    Loveland, CO
    147
    Thanks, I'll try that on the way home from work tonight!
    Loveland, CO
    147
    Engine
    ->Fuel
    Worked like a charm. As usual, Dave knows what the hell he's talking about. Just have to tweak some VE numbers down low to smooth out the idle and coastdown areas on the chart then should be good to go. Thanks!!!
    Moderator
    Mar 2014
    Raleigh, NC
    6,366
    Awesome
    Jun 2012
    230
    Thanks for all the responses. I had the VVE low to try to compensate for the 29% fuel being added during decel. The problem isn't with DFCO, as the issue is present below my DFCO disable RPM. I'll give Dave's fix a shot.
    Jun 2016
    21
    Helped my ZL1 also.
    That going lean on decel makes it hard to tune on the street. Skews the data lean.
    '13 ZL1
    Advanced Tuner veee8's Avatar
    Apr 2006
    449
    I have found on the newer stuff that if the rear o2's are not present or switching correctly, it will do this as well.
