LS2 & ID1000cc
I am looking for some injector tuning help. Motor is stock LS2 and will be running injector dynamics 1000cc. I'm sure its been discussed here before but I can only input 63.5lb in the IFR table. What other tables need to be changed for injectors that are larger than 63.5lbs?
Double stoich AFR table to 29.xx
Cut the injector flow rate provided by ID in half
Cut the IVT term tables in half (engine-->fuel-->general, "IVT Terms", AFR Term and AFR^2 Term)
And obviously apply the rest of the ID data for short pulse adder and offset table
And you're done.
